undo a command (scripting)
All  1-10  11-15
10939.11 In reply to 10939.10
Thanks for explaining the inner workings of selection undo and for setting up access. It's going to be nice to be able make some script commands undoable.
- Peer
10939.12 In reply to 10939.10
I've had some trouble with undoing scripts that include an object picker. In one case the object picker seemed to interfere with creation of a selection undo unit. Now I've got a situation where I'm using an object picker to get an edit point so that I can move that edit point.
Here's a self-contained snippet. If you run it on a new blank file you'll see:
And then if you hit Undo you'll see an intermediate stage of what the script did:
No matter how many times you hit Undo you'll never get back to an empty environment.
Is there a way for me to clean this up so that it's neatly undoable?
var index = 0;
var destinationPoint = moi.vectorMath.createPoint(1,1,1);
var rect_factory = moi.command.createFactory( 'rectangle' );
rect_factory.setInput( 0, moi.vectorMath.createFrame() );
rect_factory.setInput( 1, null );
rect_factory.setInput( 2, 5 );
rect_factory.setInput( 3, 5 );
rect_factory.setInput( 4, false );
var objList = rect_factory.calculate();
moi.geometryDatabase.addObjects(objList);
var obj = objList.item(0);
obj.showPoints = true; // must show points to make them editable
obj.setEditPointSelected(index, true);
non-interactive object picker with allowEditPoints()
simply to get edit point into an objectList so that it can be manipulated
var objectpicker = moi.ui.createObjectPicker();
objectpicker.allowEditPoints();
objectpicker.done();
var editPointInList = objectpicker.objects;
var basePt = obj.getEditPoint(index);
var factory = moi.command.createFactory('move');
factory.setInput(0, editPointInList);
factory.setInput(1, basePt)
factory.setInput(2, destinationPoint);
// remove the original object, gather up the newly moved object, and add to database
moi.geometryDatabase.removeObject(obj);
var movedObjInList = factory.calculate();
moi.geometryDatabase.addObjects(movedObjInList);
// re-hide the edit points
movedObjInList.item(0).showPoints = false;
- Peer
10939.13 In reply to 10939.12
Hi Peer, try this:
var index = 0;
//moi.geometryDatabase.addObjects(objList);
factory.setInput(0, objList);
That removes moi.geometryDatabase.addObjects(objList); , and removes the objectpicker piece
10939.14 In reply to 10939.13
Thanks Michael for the edited code!
What you posted works for me by itself, but when I try incorporating it into the larger thing I'm working on I still have the same kind of problem with undo.
I removed the other instances of moi.geometryDatabase.addObjects() and don't have any object pickers, but the problem persists.
Is there a general principal I can use to troubleshoot this?
- Peer
10939.15 In reply to 10939.12
Hi Peer, it looks like there's a bug where undo can get confused in certain cases if you both add and remove the same object within the same command.
Show messages: All  1-10  11-15
