thin tangent lines in illustration output
All  1-5  6-11
10937.6 In reply to 10937.1
Excellent! I just discovered this today. I was doing this manually. THANKS
EDITED: 28 Jun 2023 by ZOOEN
It's not the same result that this old "one line" ? (by Max Smirnov) except the layers...
http://moi3d.com/forum/index.php?webtag=MOI&msg=7912.4
(not re-tested :)
EDITED: 28 Jun 2023 by PILOU
10937.8 In reply to 10937.6
I appreciate it Zooen!
Pilou: Max's script that you linked exports to STEP and then imports the STEP back in. For curves, that merges the curve segments together which means that extruding the curve will only have 1 seam. But, I don't think Max's script has any effect on surfaces or solids.
This plugin doesn't actually change geometry. It just assigns tangent edges to a new style and hides seam edges. It's basically automating what you would do if you selected tangent edges one at a time and assigned them to a style and if you then selected seam edges one at a time and did Edit > Hide.
- Peer
10937.9 In reply to 10937.8
Thx for the infos and precisions!
10937.10
Thank you, just found this, looks very useful in certain circumstances
-James Elliott
www.jameselliott.co.uk
10937.11
Here are three presentations:
1- All edges are hidden (aesthetically, I don't really like it)
2- All edges are visible
3- I control the tangent edges and seam edges easily and quickly with the help of "tangentStyler.js" and type and style browser. For a result that suits me aesthetically for a presentation or a technical document.
- Zooen
EDITED: 18 Aug 2024 by ZOOEN
Show messages: All  1-5  6-11
