Scripting notes, 2023
All  1  2-5
10932.2 In reply to 10932.1
Hi Brian, yes by default scripts are only loaded into memory once and cached for subsequent runs.
There's a link to how to disable that here:
https://moi3d.com/wiki/Scripting
> I suppose there is some way to script assigning an object to a group...
You can do it by creating a new group using the group factory, check out Group.js for an example.
10932.3 In reply to 10932.1
Re: styles
Here's how I got the style colors for later use in some debugging (I wanted colored point as well!):
var debugRedStyle;
var debugGreenStyle;
var styles = moi.geometryDatabase.getObjectStyles();
for ( var i = 0; i < styles.length; i++)
    if ( styles.item( i).name == 'Red')
        debugRedStyle = styles.item( i).index;
    if ( styles.item( i).name == 'Green')
        debugGreenStyle = styles.item( i).index;
--Larry
Thankyou Michael and Larry.
Today I managed to create and name pointD, which does not show up in the Geometry. It seems to be "everywhere", but cannot be seen on the screen.
In the objects box, selecting the name pointD shows 1.#QNAN00 X 1.#QNAN00
which I guess means "no such number" or something.
The math equation of the point coordinates must be generating a non-number...(?)
Anyway:
Mouse scroll box of any blank area of the screen indicates that pointD has been selected.
Mouse scroll box select of any other point showing on the screen, shows there to be one extra point.
Mouse point selection, of say pointA, and hiding it, gets rid of the dot on the screen. (But blank area selection there still indicates (invisible) presence of pointD.
Weird result...
10932.5 In reply to 10932.4
Hi Brian, the 1.#QNAN00 is "not a number":
https://en.wikipedia.org/wiki/NaN
Usually it's the result of a division by zero. So probably something's not right with the calculation.
Show messages: All  1  2-5
