Light Tracer
All  1  2-6
10931.2 In reply to 10931.1
Hi Brendan, does it work better if you use .obj format and set the option in MoI's mesh export dialog for "Output: Quads & Triangles" ?
10931.3 In reply to 10931.2
Thanks Michael I'll try that now - I often forget about those output options....;)
10931.4
Hi Brendan,
I'm using LightTracer 2.5 (registered) on an M1 MBP. I've had great results using both STEP and obj formats.
.3dm does not work for me either.
Dinos
10931.5 In reply to 10931.4
Thanks Dinos - yes the .obj format as Michael suggested seems to be working fine :)
10931.6
I don't know if it goes for Light tracer, but in some render apps, if all objects are imported as 1 object, it is because the objects are all "unnamed". naming them imports them as separate objects.
Show messages: All  1  2-6
