Limitations of Moi3d?
 1-9  10-29
10927.10 In reply to 10927.9
Hi Burr, thx for your response.
seems this is way more difficult than I originally thought.
I would piece meal the parts out as you suggest, but the beauty of these, is the wood itself...
I am not aware of any 3d printers that can replicate wood.
But, nonetheless, a smart approach for a painted version.
Speaking of not getting good answers from makers, I just noticed on the ShopBot web site, they do not even sell the indexer with the ATC Max version... something they prob. overlooked.
Maybe this is why Michael suggested a dedicated cnc lathe, as it might be too complex for an indexer on a flatbed.
Legacy CNC in UT makes a machine that seems to focus on these types of turnings... maybe I should look at their system next... lots of twists n turns here, but better find out now of all the gotcha's up front...
EDITED: 24 Dec 2022 by DOLPHIN
10927.11 In reply to 10927.8
Hi BG,
> My thought was, on a flatbed CNC w indexer, I get the benefits of a flatbed cnc, indexer and
> ATC. vs. a CNC lathe only, which is about the same price with no ATC and no XYZ flatbed
> capability. But its possible, I am overlooking something....
I guess my concern is that even though this may be true, it's an overall more complex system with more things to manage while a lathe is purpose built specifically for turned pieces.
Just as a general concept jumping in to a more complex setup right off the bat will likely steepen the learning curve.
10927.12
HI BG,
I get involved with all types of work cnc based for others mostly, the majority of my work is done by hand. However I do use and help others with drawing for cnc and do a lot of high level 3dprinting and for this I use 98% MoI, the rest being done in Rhino, 3D Coat and Blender. For upto 3 axis I use MeshCAM($250 for Basic and $500 for pro), for upto 5 axis I would probably look at using MadCAM, as an add on for Rhino. I was talking to them a couple of years ago and they were looking at writing a standalone version to work with MoI, but I don't know if this has happened yet.
Re How you are looking at working I would use a standardised cnc, xyz with a rotary encoder as 4th axis. I had one built for me exactly to this spec a couple of years ago by https://amastone.com/cnc-router-marble-amastone-next/.
If all of your pieces are basically cylindrically based then I would probably look at a cnc lathe as they take top far less space, but you'd probably need something like MadCAM to drive it. https://youtu.be/uPS7fYY8tt0
Hope this helps, get back to me if you need any more info
- James
www.jameselliott.co.uk
10927.13 In reply to 10927.11
Fully agreed...but I was gonna hold off on the indexer purchase till after I mastered the flatbed...
I just wanted to be sure I bought a system that would easily expand into making the Helix....
your idea of a dedicated machine makes sense, but the cost of the dedicated wood CNC lathes seem to cost more than this entire setup, i.e. flatbed, ATC and indexer.... I guess the wood CNC lathes are much lower volume...dunno...
10927.14 In reply to 10927.11
Thx James for your input...
The CNC u referenced seems to be for stone? I am sure it cuts other materials...also from euro, whereas I prefer USA maker for local support. But what you described is what I was pursuing, till I just found this bottleneck with ShopBot ATC MAx with the indexer...hence why next week I will look at Legacy Mills, as they seem to really specialize in the xyz and indexing, even using their own CAM. They show a lot of those Helix's made pretty easy with the CCAM package, quite interesting. They seemed to be advanced in that area.
https://lwmcnc.com/cnc-systems/
I have size limitations as well, so that limits my options as well... I dont plan to cut full size 4x8 sheets.
I will prob. end up 60% on the indexer and 40% on the xyz.
Thx for the tip on MadCAM, never saw that one before.
using xyz and indexer sure complicates the software end (when doing more complex index work)... was hoping to reduce the number of packages I need to buy and learn, but that's might not be possible. A couple of CAD and a couple of CAMs might be whats required...
10927.15 In reply to 10927.14
Amastone, started from a stone background, but my cnc they built for stone, wood and brass. I have found them very helpful. Ias fas as I can tell most of it is down to spindle spec! They made mine in a special size as I only had a narrow place to put it and in Stainless Steel.
I would be interested to see where you end up with what you are doing both machine and software wise...
-James
10927.16
@BG : just so you know, MOI3D is actually incredibly powerful for 2d drafting/drawing. It may not have drawing constraints like regular 2D CAD software, but the speed of use in incredible. It's so powerful in fact that I've personally started to use it for freehand 2d sketch work (as in : with a graphics tablet) besides regular CAD drafting. I do sometimes wish it had proper parametric drawing/history features, but in practice editing is just so fast that it isn't even needed.
It is also way, way more user friendly than regular vector software like Inkscape/Affinity, because it give a much more direct controls on the shape objects. Of course it doesn't have any filling or stroke options, but that's obviously not needed for your CNC use.
I hope this helps.
10927.17
Good day.
Before I bought my cnc the top 4 machines I looked at was Avid cnc, Cammaster, Shopsabre and Legacy.
I choose Avid because it was modular (you have to assemble the whole machine except the electronics cabinets).
I knew that I need to move the machine in the future and a forklift will not fit.
I have a 5x10 table with router, plasma, rotary lathe and this week I added a laser as well. I looked into the ATC as well but it is not needed yet and
I rather spend the money elsewhere for now.
I needed to know everything about the machine because if something need to be repaired I need to do it myself and the parts could be bought from a different sources as well.
My advice if you are committed to buying a machine, buy the one you want and need the first time. Also make sure whichever machine you buy has great support ...because you will get stuck at some point.
for me I knew I needed a big table and wanted to add the plasma addition.
but when I bought it I did not buy the plasma electronics and water table. after I had the machine up and running..I bought the plasma addition.
If I bought it the first time It would saved me money on shipping and time installed.
On the software side ...
I use Moi3d probably 90% of the time and the rest would be Vcarve pro. Tried Rhino but I do not need it for now.
Right now Learning Blender and 3dcoat for more artistic stuff (this will take a while). Alibre is on my list to learn parametric and the motion simulation.
Last week I was looking at Meshcam and Deskproto but since Vcarve is doing what I need no need to buy additonal software for now. Vectric software is very nice.
I do not think the model you posted should be a problem for Vectric Aspire or Vcarve Pro but not made in 1 go. (Modeled first in Moi since it's faster imo) even the top and bottom part you should be able to make without a lathe just the cnc with the correct bits.
Here is a video of Avid rotary in action (not mine) https://www.youtube.com/watch?v=wr7ckMyfCmc
I wish I have bought my cnc years ago.
Merry Christmas to all.
EDITED: 25 Dec 2022 by MATADEM
10927.18 In reply to 10927.16
Pior, thx for response...
Glad u enforced what I thought, it seems Moi is very 2d friendly.
I am interested if you find the tablet experience faster than PC? I have a pc tablet...
Also, does anyone have any experience with the 3d CAD mouses, is it Moi compatible? real world benefits?
So Moi will not do fill ins, such as photograph of different species of wood... right? Where would I go next to accomplish that task so I can produced realistic renders? hope there is something short of Rhino. Will next version of Moi have this feature? Any plans for basic CAD fill, such as hatches, dots, etc.?
10927.19 In reply to 10927.17
Matadem, thx for ringing in... seems u have been in my shoes not long ago ;)
Several questions for you, as u have direct experience with where I am heading...
First, I spoke direct to Vectrix tech support, they can not cut Helix.... only 2.5D, i.e. wrap around 2d cuts. They researched it hard before confirming, so I assume they got it right... It appears a more capable CAM is required...
I was considering an AVID, love the flexibility. Then I watched a you tube video of a guy who owns Avid then an Phantom, and he showed how flexy the avid frame was, which is why he could not get the repeatability he desired.... which was acheived on his phantom...or any solid welded base machine. I plan to do very fine work, joinery, etc, where accuracy is mandatory. Hence why I was swayed away from AVid. I am curious of your thoughts on this? They reviewer was not trashing Avid, as he still owns one.... but it did make me feel as if rigidity should be a priority?
https://www.youtube.com/watch?v=OjruXNz_9hk&t=465s
Although, re checked the avid web site and the desk top unit appears to be sturdy option, as it has no legs...hmmmm....
The other issue with Avid was no ATC supported by the company... although a 3rd party unit is available, but fear the support issue...
any input would be helpful...
10927.20 In reply to 10927.18
Hi BG,
MoI does support the Space Mouse from 3DConnexion. re: real world benefits - it's basically personal preference some people like them others do not.
MoI doesn't do textures and rendering, you would need to use a separate rendering program for that. A couple that you might check out are Octane, KeyShot, SimLab Composer or Blender. SimLab Composer has a free version that works well, that would probably be a good one to start out with.
< Will next version of Moi have this feature?
No probably not.> Any plans for basic CAD fill, such as hatches, dots, etc.?
I would like to implement these eventually but I don't know when it will happen. Currently if you need to do filled shapes you would need to do that in a different program.
10927.21
@BG : By tablet I just meant using a graphics tablet as an input device. In my case, even though my main use for MOI is CAD drafting (with mouse and KB), I do sometimes use it for freehand sketching with a Cintiq (graphics tablet with built-in display) using a modified version of the Sketch tool with smoothing disabled. What I like about it is that it gives me a canvas with infinite resolution, something that regular painting software rarely has. As well as the ability to very easily edit sketches after the fact at the stroke level.
Also, I found out after a little while that stroke and fill settings typical of vector drawing software weren't really that much needed in my case, as I was satisfied with doing the rendering of my MOI output directly in raster at final resolution in Photoshop as opposed to doing it in vector - hence skipping the Inkscape/Affinity step altogether. With the added benefit of not having to bother with UVs, proper material setup, and so on.
10927.22 In reply to 10927.20
Thx again Michael.... you have been so helpful guiding me in the right directions, mucho appreciated.
It's so impressive to experience such dedication to customer service. Very refreshing in todays world where the opposite is the norm.
I am curious, how long have you been developing Moi? Is Moi USA based?
I noticed the pop up num pads for number entry..... was part of the inspiration of Moi to make this a tablet oriented program? About how many Moi users are there?
10927.23
BG
There are many people and business running Avid cnc.
However a heavy welded frame is always better than an extrusion frame (The same reason Machinist love the old heavy cast iron lathes and mills, they are heavy and have lower vibrations)...at first I wanted to build my own frame with Avid components.
But since I had much to learn I bought just about everything they were selling. I do not need production speeds and also since I have 2 z axis motors I do run it a bit slower.
Future plan is to have a dedicated Plasma cnc Avid as well so I can use the components that I have already. and now that I know more I can make a welded frame.
It's better to have the machine first to make parts for your next machine :).
for the ATC i got into contact with the company they responded quicky and got the pricing...but it is not a priority for me.
I found out about Phantom after I bought my machine,,,the machine looks good...however I do not like the cabinet style controllers (personal choice). monitor when it breaks I just go out and buy a new one. If my pc controller break I just get a new cheap one. locally available.
The way the other cnc have their lathes installed on the side got me interested to do mine the same way.
Since you are wanting to do intricate stuff take a look at these as well
https://www.camaster.com/machine-options/
https://www.youtube.com/watch?v=67LekRPkhNM
I noticed that Cammaster use yaskawa electronics...my experience with yaskawa vfd drives they are much more reliable than ABB, GE, Mitsubishi and Allen Bradley drives.
Avid uses Delta drives I still had no problems and if something happens I can get one from amazon or ebay.
Again imo support and parts availability is important when buying expensive machines.
if it is for business I would buy a turnkey machine ready to go.....mine is more for hobbies as I always making stuff and modular was the main selling point for me.
On the software side maybe check with Deskproto if they can do what you need.I only use vcarve. if you are going to do signs you most likely to end up with Vectric anyways.
I was always interested in 3d modeling tried many times and gave up when I found Moi3d I was able to draw something the same day. So I bought it and use it almost dialy for just about everything 3d printing, wood working design, metal designs etc. You can always use it in combination with other programs Rocket3f, blender, 3d coat etc. which is what I am planning to do.
10927.24 In reply to 10927.23
Matadem
I should have mentioned, a few users of Deskproto stated I can cut helix w their CAM...they do true 3d on 4th axis, not 2.5D. I will eventually confirm with DProto...this is becoming a full time job.
Fully agreed, it seems at this price point of CAD software, u have to accept buying a few programs if you have special needs... fortunately, the price is not too bad, at least the ones I looked at so far. I will review some of the other ones u stated when I have time.
I will have to re look CAM Master CNC, interesting info on the reliability of the VSD drives. I might re consider the shopsabre too, as I really like the rotating knife cutter. I am trying to squeeze a lot of uses into a small machine. Unsure if its all possible yet, but might as well aim high... while u own a cnc, it make sense to have available some additional features, even if not purchased up front, like engraving, cutting, marking, indexing work...and in your case, plasma! I will prob. not move in that direction.
Of course I agree with your assessment, more mass is better, almost always...but OTOH, there is other considerations as you correctly point out, such as getting it through the door opening, moving it, etc. The desktop Avid seems solid if put on a rock solid base, even if wood.
10927.25 In reply to 10927.22
Hi BG,
About 18 years now, time sure goes by fast!
> Is Moi USA based?
Yes.
Yes, making a CAD program that was friendly to artists using a pen tablet was the initial focus.
10927.26 In reply to 10927.25
Wow, 18yrs! Impressive run for sure!
It seems your software flies under the radar a bit. I never heard of it, till one artsy guy mentioned to check it out. I will surely spread the word.
Seems very labor intensive to deliver such a product today with so many operating systems, processors, tablets, pens, languages, file comparability, support, etc. I assume this must be a full time endeavor?
10927.27 In reply to 10927.26
Hi BG,
Yes I rely heavily on word of mouth so I appreciate that!
Yup, it's been full time for all 18 years.
Thanks, - Michael
10927.28 In reply to 10927.1
hi BG,
happy new year!
I am a woodworker too and using a CNC, and a can reassure you, MoI3D is the only app you need for this. I have been using MoI for over 16 years now, and never had a situation where it felt short. yes, parametrics would be nice but not indispensable.
And believe me, Moi has one of the smoothest learning curves I encountered in my 35 years of using 3D software. Its interface is simple and yet totally versatile, and there are lots of nifty things that make the use very intuitive and productive.
oops, I was lying... for organic woodworking projects I use Blender, an open source software that exports STL files. But organic isn't really CAD, is it...
bottom line: you will love MoI as soon as you get the hang of it, emphasis is on 'soon' ;-)
wim
Ghent, belgium
EDITED: 2 Jan 2023 by WIMVERBE
Size: 336.3 KB, Downloaded: 58 times, Dimensions: 1118x1140px
If you want some rustic SubD modeling that be possible directly inside Moi! ;)
https://moi3d.com/forum/index.php?webtag=MOI&msg=9689.1
If you want a true SubD prog with the same interface than MOI !!! And direct Import / Export between the 2 applications (<-->) and with a shortest learning curve than Blender!!!
free Rocket3F https://www.rocket3f.com
EDITED: 2 Jan 2023 by PILOU
Show messages:  1-9  10-29
