On disambiguation of selection in wireframe view
All  1  2-9
10926.2 In reply to 10926.1
Hi Pior,
> Is there any way/setting to make the selection of solid objects appear clearly in wireframe view, somehow ?
You should be able to see the edges flash when you click on it, but other than that no.
When you're working directly with the objects I would recommend to set the objects back to normal display mode so you can see the selection.
MoI is not really set up to work with solids in wireframe display only.
10926.3 In reply to 10926.2
Hi there Michael, Merry Xmas to you :)
I see. I usually disable any sort of confirmation flashing and/or pre-selection highlighting in any software I use as I find this kind of visual markers very intrusive (on top of being un-necessary, as IMHO a well designed mouse cursor changing with context and a good selection paradigm should be enough to tell, and I find this to be the case in MOI). Because of that, I have all these things disabled, probably thanks to a few .ini settings. Which one in particular would allow the flashing to be re-enabled ?
If anything I could see this being useful as a custom toggle, done through script and assigned to a custom button in the UI - so if that is possible I'd sure love to know how.
Thank you for your help as always !
On a side note I should have pictures of a lasercut Xmas present fully designed in MOI to share soon :)
10926.4 In reply to 10926.3
Hi Pior, Merry Christmas!
Look under [Selection] DisableSelectionEdgeFlash, if you've modified it to DisableSelectionEdgeFlash=y set it back to the default DisableSelectionEdgeFlash=n and then you should see a reaction when you select a solid that has only edges being displayed.
Currently that's not possible, it's only being read from moi.ini and it's not accessible to script. I'll set up access under moi.selection.disableSelectionEdgeFlash for the next release.
10926.5 In reply to 10926.4
Hello !
Understood - this is already a good enough workaround, as I can simply have this written as a note at the bottom of my custom UI and then open and edit the .ini as needed for this tweak. (I can confirm that it does indeed make wireframe mode usable again for me). Is there a markup code (CommandButton or MenuItem) for the "Edit ini file" button, to put it in the main UI ?
While on the topic of clear visualization here are some more thoughts.
- I think it would be useful to have the option for see-through lines to also apply to non selected objects. That way one would be able to see everything about a part assembly at a glance without the need to select anything.
- Also (and perhaps this is tweakable already), the see-through effect could benefit from having more contrast (here using continuous lines for the sake of the example, but darker dashes could work too). All optional of course.
I hope this helps.
Best,
P.O.
10926.6 In reply to 10926.5
Hi Pior,
Yes, you can find the current button inside GeneralOptions.htm inside the ui folder. It's this part
that you would put on a button:
onclick="moi.settings.editIniFile();"
It is already set up like that by default. If it isn't working like that for you, then you've probably modified a
setting in moi.ini. Look under [Hidden lines] HiddenLinesSelectedOnly=y
The default is HiddenLinesSelectedOnly=n
You can adjust the opacity level in moi.ini under:
[Hidden lines]
HiddenLineOpacity=34
That can take a value from 0 to 255. You can also alter the line style under:
[Hidden lines]
HiddenLineStyle=Dashed
That can take one of "Solid", "Dotted", "Dashed", or "Long Dashed".
10926.7
Excellent, thanks ! This about covers it all, and I am totally fine with re-enabling the flashing on a per-session basis as I only need it occasionally (although I would probably use wireframe mode more often if the earlier mentionned highlight was possible, but that's besides the point of what is possible now). I also just put the button for .Ini editing directly in my tool shelf and this alone makes the process of tweaking the .ini just a little bit less tedious.
From there, a remark on settings : with the .ini having so many useful features, hasn't it reached a point where it deserve its own dedicated section in the Options, giving direct access to all (currently hidden) settings and switches ? I feel like it is now way past the point of hosting just a few settings only edited once in a while, and it is now really quite central to the fine tuning of the MOI experience. Being able to edit all these things during the current session and without any need to restart would be quite an improvement for the user imho ... and would perhaps reduce the amount of support questions too (this thread being an example of that).
EDITED: 26 Dec 2022 by PIOR_O
10926.8 In reply to 10926.7
Hi Pior,
It would make sense to have that. But the problem is that it will require a lot of work and while I'm working on that other higher priority things that are used more frequently would need to be postponed.
The vast majority of users don't need to edit settings in the moi.ini file. When enough people ask about a particular setting then I try to elevate it up to the main Options dialog level.
10926.9 In reply to 10926.8
That does make sense. Well, if there is ever a need for some helping hands on that (on the layout side) by all means fee free to reach out.
Show messages: All  1  2-9
