Adjust after flow deform
All  1-6  7-13
10916.7 In reply to 10916.5
Or here with the base surface sized so there isn't any margins.
10916.8 In reply to 10916.5
Or if you want to control the spacing between pieces more closely you could include some stations for that in the surface construction:
Is that, what you want ?
10916.10 In reply to 10916.9
Yes, exactly
As Michael explained, the flow depends on how the destination surface has been made.
You can see how it will react with the function "Show Pts"
Next, if you want a same border everywhere (without it inflates during flow), you have to do it after flowing with an offset function for each piece.
There is another method but much longer to have more curvy result near network method.
- do the median curve (iso or cmorph process)
- Use a array/curve on a base line with the median curve.
- fix the size of segments to be on the curves
- loft the segments to have the destination surface
You loft and offset your pieces next
The Show Pts gives this
Size: 41.2 KB, Downloaded: 14 times, Dimensions: 155x281px
10916.13
For any other users that might encounter the same problem.
In the end I split it in smaller blocks and flowed the design individually.
It came out perfect! and went pretty quick.
Thanks to all.
Show messages: All  1-6  7-13
