Adjust after flow deform
All  1-11  12-13
There is another method but much longer to have more curvy result near network method.
- do the median curve (iso or cmorph process)
- Use a array/curve on a base line with the median curve.
- fix the size of segments to be on the curves
- loft the segments to have the destination surface
You loft and offset your pieces next
The Show Pts gives this
Size: 41.2 KB, Downloaded: 14 times, Dimensions: 155x281px
10916.13
For any other users that might encounter the same problem.
In the end I split it in smaller blocks and flowed the design individually.
It came out perfect! and went pretty quick.
Thanks to all.
Show messages: All  1-11  12-13
