Adjust after flow deform
10916.1
Good day.
What would be the best way to adjust after flowing the rectangles on a curve?
see pic and attached file.
I have tried first with surface flow deform...but the angles between the rectangle spacing were not satisfactory.
With the curve on curve deform the angles and spacing are exactly what I was looking for.
but I still need to adjust after that indicated with red lines...and I am unsure how to move forward.
Thank you!
Size: 139.2 KB, Downloaded: 35 times, Dimensions: 478x656px
10916.2 In reply to 10916.1
Hi Matadem,
It would probably be best to adjust the shape before you do the flow, not after it.
You could do a surface-to-surface flow to apply a bulge but also it is not too difficult to draw in a bulge.
I did that in the attached example by drawing in a curve like this:
Mirror that, then draw in lines like this:
Then use Edit > Trim to cut all that up and use this as the base shape for your Flow:
10916.3 In reply to 10916.1
Also depending on how you want the spacing formed, you might want to generate the spacing separately with non-deformed cutting objects, like this:
Spacers created using Transform > Array > Curve, so they are moved and rotated into place along the curve, but not deformed:
Boolean difference the spacers from the main part:
I think, what you want have to be done with a surface flow, not with a curve flow.
You define a source surface and a target surface.
You use them with flow function.
Look at documentation here, and above all the surface-to-surface part.
http://moi3d.com/4.0/docs/moi_command_reference8.htm#flow
10916.5
Good day...still need some help here.
The curve to curve flow works good....as I do have a pattern in the rectangle and it does transform it the way I need.
The other option to draw the rectangle for the spacing works good also.
If I use the surface to surface flow it will take the needed shape but not the spacing/angle in between.
So I tought after the curve to curve flow to do a surface to surface to match the 2 curve line but I did not get what I was expecting.
I have attached what I am after....after the flow on the curve to try to match both sides of the curves as precisely as possible.
If it was just the rectangles I could just use it and draw what I need...but since there is a pattern inside this would be very difficult.
Is there a way to acomplish this?
Thank you.
Size: 218.7 KB, Downloaded: 25 times, Dimensions: 893x612px
10916.6 In reply to 10916.5
Hi Matadem,
I didn't find the surfaces you mention here inside the file, so I'm not sure what you ran into here.
You can get different kinds of results depending on how the surface is constructed, here's an example,
constructing the surfaces here using Construct > Network:
10916.7 In reply to 10916.5
Or here with the base surface sized so there isn't any margins.
10916.8 In reply to 10916.5
Or if you want to control the spacing between pieces more closely you could include some stations for that in the surface construction:
Is that, what you want ?
10916.10 In reply to 10916.9
Yes, exactly
As Michael explained, the flow depends on how the destination surface has been made.
You can see how it will react with the function "Show Pts"
Next, if you want a same border everywhere (without it inflates during flow), you have to do it after flowing with an offset function for each piece.
There is another method but much longer to have more curvy result near network method.
- do the median curve (iso or cmorph process)
- Use a array/curve on a base line with the median curve.
- fix the size of segments to be on the curves
- loft the segments to have the destination surface
You loft and offset your pieces next
The Show Pts gives this
Size: 41.2 KB, Downloaded: 14 times, Dimensions: 155x281px
10916.13
For any other users that might encounter the same problem.
In the end I split it in smaller blocks and flowed the design individually.
It came out perfect! and went pretty quick.
Thanks to all.
