pdf import?
All  1-3  4-8
10915.4 In reply to 10915.3
Hi Bodo-Lutz,
> Hi Michael
> this pdf file for example
Yes, that PDF file contains a bitmap image like I was describing above.
If you open it in a PDF viewing program and zoom in to some of the lines, you will see a result like this:
Notice how when zooming into the lines, they get all blocky and jagged looking?
That's happening because the data contained in the PDF is a bitmap image, not drawing elements like lines and circles.
A bitmap image has data in the form of a whole lot of little colored squares. It may have the general appearance of lines when looking at a zoomed out view but it's not really line data. PDF content that uses vector graphics elements instead of bitmaps will have a sharp smooth looking appearance even when zoomed in.
So yes that PDF can't be loaded into MoI because it only contains bitmap image data inside of it and not vector drawing elements like lines.
If you use a PDF viewer program to extract the image into a PNG bitmap image file you could place it as a background image in MoI using the View > Image command, and then use that as a reference image to trace over.
But there is not any lines or curve geometry in the PDF file to be loaded as lines and curve objects in Moi.
Perhaps it could help you.
Vector graphic software like Inkscape, is able to digitalize bitmap pictures.
So, you can
- import your pdf file in Inkscape
- you have to ungroup your object (because Inkscape see in a pdf a group)
- select the picture
- use the function Path/vectorize bitmap
- use a single path option and validate
- you have now a bitmap and a vector object.
- delete the bitmap
- save your file as SVG file or pdf (this pdf will be a vector pdf)
Moi can import SVG files or pdf vector files.
Test it. It could be part of your need.
Or this other free one when you have an Imge of your PDF...
https://www.autotracer.org/fr.html
10915.7
The best is to redraw with a CAD application or with Moi3D using bitmap image from PDF as a reference.
https://moiscript.weebly.com/vectorisation.html
You have also the Hight Map inside Moi by Max for make volumes from images grey scale..
https://moiscript.weebly.com/heightmap.html
Show messages: All  1-3  4-8
