Find center of 2 curves
All  1-2  3-10
Another trick ;)
Menu Transform / Array Curves 3 (objects) Points!
10913.4
going to check it out tnx!
10913.5 In reply to 10913.3
> Another trick ;)
I don't think that trick will work, since Array curve will make exact copies of a base object that are moved and rotated along the path curve.
Array curve will not morph a curve's shape between 2 different shaped curves as being requested here.
10913.6 In reply to 10913.5
Sorry I have believed that we must found the middle of each curve...(literal meaning)
So if i repeat the process on the second curve ( array curve again for to know the middle of it)
I can draw a point at the middle of the 2 curves ?
Of course the middle position of the arc is deformed by the perspective! :)
EDITED: 11 Dec 2022 by PILOU
10913.7 In reply to 10913.6
Yes you can but the question was not about how to make a point between 2 curves, it was how to make "median curve" between 2 differently shaped curves. Take a look at the image in the first post.
- MIchael
10913.8 In reply to 10913.7
Ah ok! That is not effectively exactly the same! :)
So maybe Line Web can works...
Rebuild the 2 curves (10 pts )
Lineweb Lines (between the 2 curves)
LineWeb again 3 points / Curves (between the 10 lines resulting previously)
Order of selection is necessary!
10913.9 In reply to 10913.8
It could but it's more work than using Loft + extract isoparm.
10913.10 In reply to 10913.9
Yes Loft / Iso seems more speedy!
and it's a luck that we can snap on the "middle" for the "V" because seem impossible for the "U" !
Show messages: All  1-2  3-10
