Making a sheet metal pattern from a Truncated Cone
All  1-5  6-19
10908.6 In reply to 10908.5
Hi Gunter,
I think I'd fix the model first, making sure that it is using a 1mm thick sheet.
If you're concerned about the size, maybe it would make most sense to make a cone through the mid-thickness of the model's sheet and then unwrap that? Similar to how you'd plan bends in other stock, use the middle line allowing for compression and shrinking of the inner and outer surfaces. Trial run in brass certainly makes sense to verify result before working with the silver! What is it that you're making?
_ConeUnwrap is a neat script Brian!!
--Larry
I spent an hour or so trying to do a random cone, with some frustration :-)
I should have used Gunter's model...
My attempt did not produce planar seam, but should have...
Probably best not to post my goofy attempt...
The "cone" apex of the outer frustrum is higher than the inner frustrum's apex.
The unwrap of the inner frustrum needs to be rotated a little, and moved a little...and offset by thickness...
Maybe cut the 3d solid frustrum, with a very tiny wedge, and Flow the solid to the outer frustrum unwrap???
Edit, cut the solid frustrum in half with 90 degree cuts (?), and discard half, and Flow half to a flat, and then double it...???
10908.8 In reply to 10908.6
Hi again Larry,
I will try that and see what happens. I'm trying to use moi3d rather than traditional methods
of creating a collet for a large round but shallow Peridot.
Lets see how it goes :)
Thanks again!
Gunter
10908.9 In reply to 10908.7
Thank you for taking the time for my issue!
I'm going to attempt this in brass first and see where it leads me.
Much appreciated,
Gunter
10908.10 In reply to 10908.3
Explanation in regards to "extendDistance" paragraph:
If a line is drawn perpendicular to the top point of the outer slant seam line, which is also perpendicular to the outer face of the 3D frustum, the intersection with the inner face will be offset from the end point of the inner slant seam line. And vice versa for the lower point of the slant seam line.
Attempting Flow, no luck so far...
Success with Flow!!!
Using Half of the cone as a Solid, and another silver copy of the outer half face of the half solid as base surface, the solid will flow correctly to a planar unwrap outer surface.
However, rather than using Planar on the unwrap, which produces rectangular isolines, use sweep of one of the unwrapped slantseams, to sweep the arcs of the unwrap frustum.
This produces the proper isolines.
I do see some little artifacts on the smaller arc...?
And no confirmatory measurements were made.
I'll have to try the full frustum solid...
10908.12
Using the flatten surface command in RHINO.
Solid Frustum Unwrap using UnwrapCone2 script and Flow, and other routine MoI commands.
("Final" summary of procedure.)
Begin with a solid Frustum, which is a cone with a smaller cone located inside, with the same axis, with the tops cut off with a plane. Thickness is constant. (e.g. Sitting in Top or Bottom view) (Join may be used to create the solid.)
Use the script UnwrapCone2 to unwrap the outer cone surface, to produce 3 arcs and two lines. Trim off the apex portion of the unwrap, to leave the planar outline of the frustum. Trim away half of the planar arc.
Sweep the planar (half) frustum with one edge line, to make curvy isocurves, visible with Curve>Iso command. This planar arc surface is the Target for Flow. (Rectangular isocurves do not work here. The planar isocurves must correspond to the isocurves on the outer frustum surface.)
(e.g. in Front View) Create a plane passing through the slantseam, to divide the frustum into two portions. Return to Top view and Discard half of the frustum. The make the remaining half a solid, may need another trim utilizing the plane, and a join.)
Copy the remaining (half) outer face of the solid (half) 3D frustum, off to the side, and set it to a different color Style, to facilitate hiding and unhiding selection in Flow to come. This will be the Base surface for Flow.
Select the 3D (half) frustum solid, and select Flow. Follow the Flow directions.
Hide the solid using its color Style eye, and select the previously prepared Base surface, near a corner. Select the target planar arc near corresponding corner, and complete the Flow.
The result is thick, flat, unwrap of half of the solid frustum, with the arc sides beveled. This can easily be doubled.
(Minor face artifacts could be deleted and replaced with ending sweep???)
-Brian
Flow of Full frustum was not successful...
I imagine that a hole in the half frustum solid would also transfer with flow???
EDITED: 4 Dec 2022 by BEMFARMER
10908.14 In reply to 10908.5
Hey Gunter,
“””””” I'm just not
sure if it should be the outer or inner? I feel if I use the inner unwarp, it might to too small?””””””
Taking the thickness into account is a bending thing as metal doesnt bend with exact dims. But for your cone unwrap, it will only affect the “seam” and it will have an “angle” instead of original flat ends.
When you coil your cone, the first part to touch will be the inner edge and you will be welding the seam shut on the outside.
For most accurate results, use the inner surface as your unwrap, then bead and fill the gap on the outside.
In theory, if you did both unwraps, you can determine the angle of the ends and the roll your cone to have no gap when it meets. Or determine your dims at centerline or something other than….
I am not a jeweler or silversmith, but this link was interesting.
Making a Band Ring:
https://www.instructables.com/A-simple-Sterling-Silver-Band-Ring/
EDITED: 5 Dec 2022 by BEMFARMER
10908.16
Fwiw, there is a software called Lamina out there that takes a 3dm (version 4) and creates flat sheet cutouts with all bells and whistles : www.laminadesign.com
It was quite expensive at its time, but the author lowered the price to a whooping $1.80 (one dollar, eighty cents) for commercial usage.
10908.17
FreeCAD can unroll cone surfaces and much more.
10908.18 In reply to 10908.1
Here is a video I did for a guy with another software, but the method is using the math needed which Michael gave me here!
So the thread regarding the math and needing the radians value is here in the MoI forum somewhere. Thanks again Michael!
If you want to just see the math, you can skip to 4.10 of the video. Then you don't have to sit through me explaining....
10908.19 In reply to 10908.18
Nice suggestion, the best one.
Show messages: All  1-5  6-19
