Ugrinsky Rotor
All  1-2  3-8
UgrinskyCrossSection03.3dm is a Left Handed helix spiral.
Turbine deflects wind downward? Lift force occurs? Less efficient than RH?
Could mirror cross section?
Instead, will redo as RH spiral.
EDITED: 19 Nov 2022 by BEMFARMER
10897.4 In reply to 10897.3
This is really interesting Brian,
Thank you
James Elliott
www.jameselliott.co.uk
10897.5 In reply to 10897.1
The cross section has similarities to the famous yin-yang symbol!
Thanks for sharing this Interesting info!
The .step models at mcmaster quickly open in MoI, and can be saved as .3dm files.
I plan to use one of these bold models to boolean difference a solid block model, to make internal threads.
https://www.mcmaster.com/screws/system-of-measurement~metric/metric-18-8-stainless-steel-button-head-hex-drive-screws/
Also, there is a more efficient radius setting for the rotor.
The smaller radius blade diameter is 0.35 * Diameter of rotor.
The larger radius blade radius is still = L = 1.0 * R = 1.0 * D/2. Depending on the ratio of rotor tip speed to incident wind speed, the 1.0 factor could be 1.3.
So I am re-doing the model...
https://www.witpress.com/Secure/elibrary/papers/ESUS21/ESUS21011FU1.pdf
This paper was with non-spiral rotor.
I have not seen any data for a helical rotor.
10897.7
Some notes on Helical Wind Turbines, this might provide some useful input to the discussion:
https://windcycle.energy/helical-wind-turbine/
best regards
O.
10897.8 In reply to 10897.7
Thank you for the link, Ken.
Show messages: All  1-2  3-8
