Is displaing undercuts possible ?
All  1-5  6-7
10896.6 In reply to 10896.5
> So to clarify my understanding, the Sillouette result depends on the View, or cplane view "direction".
Yes it's the view direction. Except for if you use the 3D view and it's a perspective projection. In that situation it traces a silhouette based on the projection of a point in 3D space towards the camera/eye point.
> And this direction corresponds to a "pull direction" that would be impeded, for a mold to form the object would use, to release the object?
Correct.
> So a different pull direction would be needed, to release the object? Or the object might need to be cut into different sections?
I think usually it means the object needs to be modified so that it doesn't have an undercut like that.
10896.7 In reply to 10896.6
Michael, thank you for your clarification.
Show messages: All  1-5  6-7
