Is displaing undercuts possible ?
All  1  2-7
10896.2 In reply to 10896.1
Hi Tanguy, there is not a display mode in MoI for showing undercuts but there is a Silhouette command that can generate curves at places where there are undercuts.
So for example with an object that has undercuts like this:
You can select it and run Construct > Curve > Silhou :
Set the option for View : Top and it will generate silhouette curves in the z axis direction which will be parting lines and also be present at undercut areas:
10896.3 In reply to 10896.1
Google of "cad undercuts display"
An undercut is a design feature that interferes with the ejection of a molded part from the mold. An undercut can include features such as holes or boses that are not aligned with the direction of ejection, threaded sections, and snap fingers.
https://knowledge.autodesk.com/search-result/caas/CloudHelp/cloudhelp/2016/ENU/DFM/files/GUID-CCAB8DFA-9719-44C3-9C88-0C5A3185C148-htm.html#:~:text=An%20undercut%20is%20a%20design,threaded%20sections%2C%20and%20snap%20fingers.&text=The%20snap%20finger%20shown%20above%20has%20an%20undercut%20surface%20highlighted%20in%20red.
For a rotary shaft with an "undercut", a keyway,
this link has 3 good points:
1. Illustrate as a cross-section...
2. Never dimension to hidden lines.
3. The axis should be drawn so everyone can tell at a first glance. (Whatever that means?)
4. Dimension key cuts as a diameter of the shaft, from the bottom of the cut to the "other side" of the shaft, not as a depth of the cut.
https://www.reddit.com/r/AskEngineers/comments/fore6a/in_cad_drawings_is_it_common_practice_to_omit_the/
https://imgur.com/1UWrBiQ
https://www.aegisdentalnetwork.com/idt/2011/10/the-cad-in-cad-cam
"Just about all CAD programs today automatically block out undercuts with a click of a button or check of a checkbox."
(Expensive dental CAD)
https://www.protolabs.com/resources/blog/design-validation-with-solidworks-injection-molding/
- Brian (I have no personal knowledge on this subject. But learned a little bit...)
10896.4 In reply to 10896.2
Thank you so much for such a detail answer ! You won a customer for sure :)
10896.5 In reply to 10896.2
So to clarify my understanding, the Sillouette result depends on the View, or cplane view "direction". And this direction corresponds to a "pull direction" that would be impeded, for a mold to form the object would use, to release the object? So a different pull direction would be needed, to release the object? Or the object might need to be cut into different sections?
EDITED: 16 Nov 2022 by BEMFARMER
10896.6 In reply to 10896.5
Yes it's the view direction. Except for if you use the 3D view and it's a perspective projection. In that situation it traces a silhouette based on the projection of a point in 3D space towards the camera/eye point.
Correct.
I think usually it means the object needs to be modified so that it doesn't have an undercut like that.
10896.7 In reply to 10896.6
Michael, thank you for your clarification.
Show messages: All  1  2-7
