STL to Stp
All  1-4  5-6
10892.5 In reply to 10892.1
There is actually a way to do this in FreeCAD. Tried it with a simple model to see if this works,
see screenshots.
After opening the converted model in Moi, it shows up as a solid and is editable.
Here is a link to a youtube video that explains the process. Not sure which results you
get with more complex geometry.
FreeCAD Useful Tips and Awesome Tricks with @WayofWood! |JOKO ENGINEERING
https://youtu.be/0zxjOB2Cao8
It's the second tip. Hope this works for you. I don't think you can avoid the meshlook
on rounded/curved surfaces.
Size: 40.8 KB, Downloaded: 47 times, Dimensions: 400x348px
Size: 40.8 KB, Downloaded: 46 times, Dimensions: 1467x897px
10892.6
What I sometimes do:
- Convert .stl to .obj using Blender
- Use the "Obj23dmWireframe converter" from the Resources page
- Import the resulting 3dm file
- Adjust the scale using a known reference length along the object
- Lock the object
- Recreate the object by snapping to the points of the imported mesh
Show messages: All  1-4  5-6
