STL to Stp
All  1-2  3-6
10892.3 In reply to 10892.2
Wow, thanks for that info.. I live in a really remote town in northern Kenya and have an old slow PC and a mediocre (speed wise) connection to the internet, sooo.. I'm trying to adapt a mechanical counter I found in Printables to use it to count turns on a spool for measuring of a borehole.. Is there any way to download the item in Printables in another format?? Would I have more luck using Fusion 360?? I've been really happy with MOI and downloaded STP files from McMaster Carr..
10892.4 In reply to 10892.3
Hi ACP,
It looks like there is for some parts.
I found some info at:
https://help.prusa3d.com/article/printable-parts-for-original-prusa_1824
The ones in OpenSCAD format won't work either though, that format contains the model in the form of a type of scripting code and the end result is also faceted mesh data as well.
Probably not.
Yes the STP files at McMaster-Carr have real CAD data in them, not faceted mesh data.
10892.5 In reply to 10892.1
There is actually a way to do this in FreeCAD. Tried it with a simple model to see if this works,
see screenshots.
After opening the converted model in Moi, it shows up as a solid and is editable.
Here is a link to a youtube video that explains the process. Not sure which results you
get with more complex geometry.
FreeCAD Useful Tips and Awesome Tricks with @WayofWood! |JOKO ENGINEERING
https://youtu.be/0zxjOB2Cao8
It's the second tip. Hope this works for you. I don't think you can avoid the meshlook
on rounded/curved surfaces.
Size: 40.8 KB, Downloaded: 47 times, Dimensions: 400x348px
Size: 40.8 KB, Downloaded: 46 times, Dimensions: 1467x897px
10892.6
What I sometimes do:
- Convert .stl to .obj using Blender
- Use the "Obj23dmWireframe converter" from the Resources page
- Import the resulting 3dm file
- Adjust the scale using a known reference length along the object
- Lock the object
- Recreate the object by snapping to the points of the imported mesh
Show messages: All  1-2  3-6
