Learning to create addon
 1-6  7-26  27-32
10889.7 In reply to 10889.6
I would love to. Where do I start?
Thank you.
10889.8 In reply to 10889.7
Hi Elang,
For some generalities, here is a Word file. (If you do not have Word, it could be converted to PDF.)
https://home.csulb.edu/~pnguyen/cecs100/lecturenotes/Programming%20Development%20Cycles.docx
1. Analyze the problem. The computer (programmer) <user> must figure out the problem, then decide how to resolve the problem - choose a program.
2. Design the program...FlowChart...
etc.
Write out an overall description in "English" (or your) language, of how the interaction of the user is expected to take place.
So far you have talked about making rectangular boxes.
Three fields can be defined for Width and Length and Height.
What about thickness of the box walls?
The MoI Box command can make a Box with 6 surfaces.
The MoI Offset/ Inset command can make a box with thicknesses. A uniform thickness would be another entry field for the user.
The open top of the box must be defined and selected somehow.
I do not know how to automatically select the "Top" of the box. Maybe something in Extrude would help. Michael would know...
Define the fields desired.
Depth would depend on the amount of offset height...
Nesting boxes?
Lids?
Heart shaped boxes?
For Windows systems, Notepad++ editor can view current .js and .htm files, such as Box, Ringmaker, NutsAnd Bolts, etc.
(Do not rename .html, use .htm for extension.)
Also Notepad++ can modify existing (renamed) .js and .htm files.
I would set up a project file, (BoxMaker?), easy to find on the hard drive, or USB drive, or even microsoft OneDrive.
Copy promising files such as the three (times 2) files mentioned above, even rename them slightly, and edit them in Notepad++.
The .htm file has the list of fields. Part of the .js file tells MoI how and when to read and process the fields, and can ask the user to enter various values.
Response of geometry creation can be immediate, or there can be an Update button...
An .htm file can be run from Notepad++, for a simple view.
Work from a functioning script, making small modifications, and run in MoI, as a quick "debug." This will show the actual .htm in MoI screen...
Say change Box from interactive, to entry of fields...
You could go the nodeeditor way as an alternative.
Max's excellent scripts tend to seem abbreviated and complex to myself...
The interactive Box scripts coding is pretty intimidating to myself.
The MoI API shows the Box Factories inputs, which is fairly simple...AND even has a 7 line .js script to draw a box. Just add the .htm interface to get the parameter values.
(20 units of width, length, and height...)
Example
//Draw a box
var factory = moi.command.createFactory( 'box' );
factory.setInput( 0, moi.vectorMath.createFrame() );
factory.setInput( 2, 20 );
factory.setInput( 3, 20 );
factory.setInput( 4, 20 );
factory.commit();
EDITED: 8 Nov 2022 by BEMFARMER
The extrude command has input 5 for Cap ends.
I do not see any input to cap only one side...
Maybe that could be a feature request?
The example in the API does not show the proper inputs for 5...
extrudefactory.setInput( 1, true ); //cap ends? yes>>>>Error, should be input 5 ???
Found an answer here:
https://moi3d.com/forum/index.php?webtag=MOI&msg=9919.9
From 2 years ago.
BoxMaker
Boxmaker makes a rectangular box with thickened walls and thickened bottom.
This Example is for a box with wall and bottom thickness of 0.2 cm.
(Final version would have user control of dimensions.)
The Box's OD, (outer dimensions), are:
Height: 2cm OD, Width: 4cm OD, Depth: 3cm OD .
For inner dimensions, deduct 0.4cm from Width and 0.4cm from Depth,
and deduct 0.2cm from Height.
The Box sits on the xy plane, centered on the Origin.
1. Create Rectangle, with Rectangle Center command.
In Front View, place the center point at (x,y,z) coordinate
point ( 0, 0, 2 ), which will become top the center of final Box.
In Top View, place the corner point at ( 2, 1.5, 2 ).
This rectangle is at the future top of the box.
The rectangle may be styled black, or some other color.
2. Create Planar surface from the rectangle, and style surface cyan.
This surface will become the bottom of the box after move to z = 0.
Move the surface to z = 0, a coordinate decrease of -2cm.
3. Create a second Planar surface from the rectangle, and style it red.
Later, this surface will become the top edge of the box, and also it will become the interior surface of the box. (Liner)
4. In Front View, Extrude the rectangle down to z = 0, (-2cm).
Do NOT cap ends. Do NOT do Both sides. (Rectangle can be deleted.)
5. In 3D View, select red liner surface, and select MoI command
Offset > Inset. Check checkbox "Use Separate Height", and
set the Height to 1.8cm, Direction Inwards.
This creates the red lining and rim of the box.
Select all 11 faces, and Join to a Solid. (Or select some other automatic way.)
All of these commands can be formed in script, after the user selects the desired dimensions, without further manual selections. Maximum inset height can be calculated. The Views can be replaced with appropriate cPlanes or distances...
Hopefully there are not too may minor errors in the above text :-)
Adjustments and changes can be pretty common sense. This is a guide to additional work that could be done...
Extrude tends to make names go away.
Well, I guess that similar procedures could make a heart shaped box also. Or round or oval?
Well, Length could be called Width, and former Width called Depth, or some such terminology...
EDITED: 9 Nov 2022 by BEMFARMER
Define user inputs needed:
1. Height, default 2cm OD.
2. Width, default 4cm OD.
3. Depth, default 3cm OD.
4. WallThickness, default 0.2cm.
5. BottomThickness, default 0.2cm.
6. Lid Thickness.
Build list (drop down list) of box types:
1. Rectangular
2. Circular
3. Elliptical
4. HeartShape
5. Polygonal sides.
6. Tapered (Will need extra code for removal of Top face, and less code for bottom.)
7. ?
Define categories of boxes:
1. Bottom
2. Lid which nests over bottom.
Select a sample script to act as a partial template .js and .htm.
Some good choices:
_ChainMaker script.
_EggOvoid3 script
_Power Cone Spiral
_ChainMaker has an Update button, so many dimensions can be entered, before the geometry is recalculated.
_EggOvoid2 has a Build type menu. Geometry is updated each time a dimension is changed. There are also sliders. (Another version has a presets menu.)
_EggOvoid2 is my initial pick for a script template.
Copy _EggOvoid2 .js and .htm to the BoxMaker directory, and load into Notepad++.
In Notepad++, copy ALL, (or desired portions), of _EggOvoid2.js, to the new _BoxMaker.js copy in Notepad++. Also copy desired portions of _EggOvoid2.htm, to the new _BoxMaker.htm file in Notepad++.
(Alternatively, an extra copy of the two template files can be renamed to _BoxMaker, and loaded into Notepad++)
Two view panels can be opened in Notepad++, for side by side views, and copying between two .htm files.
(As an afterthought, most of Max's scripts utilize a lot of the .js code in the .htm file, do to old speed constraints. It is no longer necessary to put a bunch of the .js code in the .htm file. (Some of MoI's scripts do have a bit of .js code in the .htm file, for programming convenience and "ability".)>>>>>>
Edit the .htm file, and also the .js file.
Initially make the changes gradual, and minor and non-destructive.
The evolving _Boxmaker.js and _Boxmaker.htm files can be copied to the commands folder of MoI AppDate folder, and run in MoI, and so show progressive improvements, or script failure.
Keep lots of copies of evolving scripts, so as not to lose those versions which still function. If the script Zonks-Out when run, make corrections, or else revert to a former partially working copy.
It is hard to edit a variable in .htm file, and conform the other occurrences in .htm or .js.
After selecting text to find, or change, using Ctrl+h in Notepad++is very helpful.
An unfinished draft .htm attached.
Double click in file manager to see menu display.
(Windows 11, see in file manager window???)
My few years old computer is not compatible with Windows 11. Due to the lack of some security feature, and ?.
My 1 or 2 year old Dell computer has Windows 11 on it, currently at work..
Alpha1 version is slightly improved, but still needs modifications. (I had uploaded a slightly older version, by mistake.)
p.s. I am an amateur programmer, so others have more skill, and better work habits, and better naming conventions...
(I may do a little more work the next evening...)
EDITED: 10 Nov 2022 by BEMFARMER
10889.12
Hello.
I thank you very much for so many helpful replies. Please pardon for late respond since I've been quite busy lately.
I will study all of your post, and hopefully will be able to write my own script soon.
I really love MoI as much to this great forum with helpful people.
Sincerely.
10889.13 In reply to 10889.11
I tried to run this in V4 (by entering "_BoxMakerAlpha1" in the input field at the bottom of UI), but nothing happens. Is there any prerequisite to run this? Or did I take it incorrectly?
Thank you very much in advance.
10889.14 In reply to 10889.12
Hi Elang,
I will be interested in trying out the results of your programming.
So I had better move on to my other programming projects, for now at least, as it is your project.
Attached is an update of the .htm screen entry file, _BoxMakerAlpha2.htm, along with a bare bones, non-functional _BoxMakerAlpha2.js.
Load these two files into MoI AppData, command folder, to test out the .htm screen menu and dimension choices, in MoI. The script barely does anything as is.
>>>(Or you could load the scripts into the MoI Program directory with all of the stock MoI scripts, BUT using AppData is my preferred method.)
It features Sliders, with a range which the programmer decide the limits of.
Also, if a value is changed, clicking on the dimension label will reset to the default dimension.
The dropdown Build menu shows its entries.
The Done and Cancel buttons function.
It is a starting point for your BoxMaker script...
What is the minimum MyProgram.js and MyProgram.htm files to enable the testing of the simple .htm file in MoI?
(With the .js file not doing much)
The MyProgram.js file does not need much code, in order to permit rudimentary .htm testing.
Also attached are: _BoxMakerAlpha2MinTestJS.htm, and also _BoxMakerAlpha2MinTestJS.js script.
They can be loaded into MoI Appdata and run as a new script, as in 3rd paragraph above.
10889.15 In reply to 10889.13
Hi Elang,
Alpha1 version was just to view in Windows, or Edge or Chrome, but this will not show any MoI specific code...
See Alpha2 versions in previous posts.
The Min version is nearly the same as the Alpha2 version, except the .js file has even LESS code. So the Min version may be discarded.
The Alpha1.htm may also be discarded.
Either MoI4 or MoI5 beta will allow trying out the .htm entry window with Alpha2 versions.
No Boxes will be build until a lot more coding is done...
I think you will need to add in the Rectangle factory, the Planar factory, the Move factory, the Extrude factory, the Inset factory, and the Join factory.
And also do some simple subtraction of Height minus BottomThickness for Inset distance.
I do not think that numpoints will be needed, unless a heart curve is drawn.
Or, A basic heart curve could be scaled??? for an input.
The various curves and surfaces, etc., will need to be identified by e.g. Name or Color, in order to be selected for the various steps.
10889.16
I really appreciate the materials that you've post. I'm sure will have to know it very soon. The thing is, they seems to be a little bit too advanced for me (having the UI ready, etc).
I just found a discussion here regards scripts:
http://moi3d.com/forum/index.php?webtag=MOI&msg=7238.1
.. and the discussion there could be a good start for me: to draw objects using script like the following example from Martin.
script:
factory.commit();
I think I could start learning from this humble beginning.
However, I can't find the right place to have the reference for each objects, i.e.: how to use moi.command.createFactory, what parameters needed, etc.
So, could you please point me the right direction?
10889.17 In reply to 10889.16
Hi Elang,
For using moi.command.createFactory(), the example you posted shows it, you pass it the string name of a factory, in what you posted that's 'box'.
In the regular box command the inputs to the box factory are filled in by picking a point to place the corner point and coordinate frame, and then the width, height, and extrusion values are filled in by either another point pick or by values that are typed in to edit fields.
In your example code it's setting values of 20 each for width, height, and extrusion.
If you instead had:
factory.setInput( 2, 30 ); // Input index 2 is width
factory.setInput( 3, 40 ); // input index 3 is height
factory.setInput( 4, 50 ); // input index 4 is extrusion
that would make a width of 30, a height of 40, and an extrusion of 50 units.
10889.18 In reply to 10889.17
So in general the setInput indexes is something that mimics the way we input them in Moi?
Still are there any reference list for each of the command? I'm hoping something like here:
https://learn.microsoft.com/en-us/dotnet/visual-basic/language-reference/functions/string-functions
... though a much simpler way is ok.
10889.19
Found something very interesting here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=10720.5
Is this contains all object in Moi?
10889.20 In reply to 10889.19
Hi Elang, I think there's a more up to date one here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=10857.36
I think it has all of them at that point in time that it was made but it's from quite a while ago.
Yes the regular commands fill in these same factory inputs, often times by connecting them to edit fields in the UI and also some inputs take x,y,z point values that are filled in by a pointpicker.
A script can just directly fill in the factory inputs instead which is what your example code there was doing.
Well, I cannot believe this.
I was working on a super simple BoxBasic script, and either Windows 11, or a recent version of Notepad++ renamed TWO entirely different .htm files to .html.
So nothing was working.
Also, my Windows 10 file manager shows both .html and .htm files as HTML Document.
Notepad++ does show the correct extension of an .htm file, or an .html file.
For MoI scriptwriters dealing with .htm files, is may be a good idea, in Windows 10 file manager,
to select view, and check the box "File name extensions", which will display the corresponding
.htm or .html extensions attached to the file name.
EDITED: 11 Nov 2022 by BEMFARMER
Here is a very simple script to create a box, using just the MoI Box factory.
The Box seems to be sitting on the x,z plane, so I may switch to the x,y plane, the original intention, with Height in the z direction.
This can be done by just re-ordering the order of the box factory inputs.
Note that there are more than one way to make this box. There is .update and .commit.
There is .calculate, and moi.geometryDatabase.addObject( box ), with objectlists.
This box is a solid, with 6 faces. If one face is deleted, the box is a joined surface, with walls and bottom of zero thickness.
The desired box has not been specified.
My concept of what the desired box could be, is that of a candy box, with open top, and 4 sides (walls), and a bottom, all of which have non-zero width.
One way to do this, as for the previous manual method several posts ago, would utilized a half dozen or so factories, in one script...
Here is Alpha4 version, with Height in z direction.
Just swapped box factory inputs 3 and 4.
ps Change a slider, then click on input label, to restore default dimension value.
10889.24
Wonderful! Thank you very much, Brian.
I'm sure I will learn a lot from your script.
- Elang
10889.25 In reply to 10889.24
In the past, when I just cannot get a script to work, by making a question, or request, Michael has provided a lot of tremendous help!
10889.26
attached a nod file created in nodeditor that makes boxes from any closed curve profile that can be scaled.
Not sure if this is the kind of thing you are after.
Barry
Show messages:  1-6  7-26  27-32
