Learning to create addon
 1-17  18-32
10889.18 In reply to 10889.17
So in general the setInput indexes is something that mimics the way we input them in Moi?
Still are there any reference list for each of the command? I'm hoping something like here:
https://learn.microsoft.com/en-us/dotnet/visual-basic/language-reference/functions/string-functions
... though a much simpler way is ok.
Thank you very much in advance.
10889.19
Found something very interesting here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=10720.5
Is this contains all object in Moi?
10889.20 In reply to 10889.19
Hi Elang, I think there's a more up to date one here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=10857.36
I think it has all of them at that point in time that it was made but it's from quite a while ago.
Yes the regular commands fill in these same factory inputs, often times by connecting them to edit fields in the UI and also some inputs take x,y,z point values that are filled in by a pointpicker.
A script can just directly fill in the factory inputs instead which is what your example code there was doing.
Well, I cannot believe this.
I was working on a super simple BoxBasic script, and either Windows 11, or a recent version of Notepad++ renamed TWO entirely different .htm files to .html.
So nothing was working.
Also, my Windows 10 file manager shows both .html and .htm files as HTML Document.
Notepad++ does show the correct extension of an .htm file, or an .html file.
For MoI scriptwriters dealing with .htm files, is may be a good idea, in Windows 10 file manager,
to select view, and check the box "File name extensions", which will display the corresponding
.htm or .html extensions attached to the file name.
EDITED: 11 Nov 2022 by BEMFARMER
Here is a very simple script to create a box, using just the MoI Box factory.
The Box seems to be sitting on the x,z plane, so I may switch to the x,y plane, the original intention, with Height in the z direction.
This can be done by just re-ordering the order of the box factory inputs.
Note that there are more than one way to make this box. There is .update and .commit.
There is .calculate, and moi.geometryDatabase.addObject( box ), with objectlists.
This box is a solid, with 6 faces. If one face is deleted, the box is a joined surface, with walls and bottom of zero thickness.
The desired box has not been specified.
My concept of what the desired box could be, is that of a candy box, with open top, and 4 sides (walls), and a bottom, all of which have non-zero width.
One way to do this, as for the previous manual method several posts ago, would utilized a half dozen or so factories, in one script...
Here is Alpha4 version, with Height in z direction.
Just swapped box factory inputs 3 and 4.
ps Change a slider, then click on input label, to restore default dimension value.
10889.24
Wonderful! Thank you very much, Brian.
I'm sure I will learn a lot from your script.
- Elang
10889.25 In reply to 10889.24
In the past, when I just cannot get a script to work, by making a question, or request, Michael has provided a lot of tremendous help!
10889.26
attached a nod file created in nodeditor that makes boxes from any closed curve profile that can be scaled.
Not sure if this is the kind of thing you are after.
Barry
10889.27 In reply to 10889.26
Hi Barry,
You have made a very nice node!
Select a closed profile, e.g. Rectangle, Star, Circle, etc.
Run Box2.nod in nodeeditor.
10889.28 In reply to 10889.27
Thanks Brian,
the nodeditor as it’s uses for us non programmers.
Barry
10889.29
NE-Box
image host image host image host image host
EDITED: 12 Nov 2022 by WN
10889.30 In reply to 10889.29
Joinery!!! Nice WN.
Also Barry. Always great contributor! :)
Cool nodes process!
10889.32
Hi everyone, Thank you very much for such nice and helpful respond.
I'll learn a lot from all of you.
Please keep them coming.
Thank you and have a nice day!
Show messages:  1-17  18-32
