Learning to create addon
 1-12  13-32
10889.13 In reply to 10889.11
I tried to run this in V4 (by entering "_BoxMakerAlpha1" in the input field at the bottom of UI), but nothing happens. Is there any prerequisite to run this? Or did I take it incorrectly?
Thank you very much in advance.
10889.14 In reply to 10889.12
Hi Elang,
I will be interested in trying out the results of your programming.
So I had better move on to my other programming projects, for now at least, as it is your project.
Attached is an update of the .htm screen entry file, _BoxMakerAlpha2.htm, along with a bare bones, non-functional _BoxMakerAlpha2.js.
Load these two files into MoI AppData, command folder, to test out the .htm screen menu and dimension choices, in MoI. The script barely does anything as is.
>>>(Or you could load the scripts into the MoI Program directory with all of the stock MoI scripts, BUT using AppData is my preferred method.)
It features Sliders, with a range which the programmer decide the limits of.
Also, if a value is changed, clicking on the dimension label will reset to the default dimension.
The dropdown Build menu shows its entries.
The Done and Cancel buttons function.
It is a starting point for your BoxMaker script...
What is the minimum MyProgram.js and MyProgram.htm files to enable the testing of the simple .htm file in MoI?
(With the .js file not doing much)
The MyProgram.js file does not need much code, in order to permit rudimentary .htm testing.
Also attached are: _BoxMakerAlpha2MinTestJS.htm, and also _BoxMakerAlpha2MinTestJS.js script.
They can be loaded into MoI Appdata and run as a new script, as in 3rd paragraph above.
EDITED: 10 Nov 2022 by BEMFARMER
10889.15 In reply to 10889.13
Hi Elang,
Alpha1 version was just to view in Windows, or Edge or Chrome, but this will not show any MoI specific code...
See Alpha2 versions in previous posts.
The Min version is nearly the same as the Alpha2 version, except the .js file has even LESS code. So the Min version may be discarded.
The Alpha1.htm may also be discarded.
Either MoI4 or MoI5 beta will allow trying out the .htm entry window with Alpha2 versions.
No Boxes will be build until a lot more coding is done...
I think you will need to add in the Rectangle factory, the Planar factory, the Move factory, the Extrude factory, the Inset factory, and the Join factory.
And also do some simple subtraction of Height minus BottomThickness for Inset distance.
I do not think that numpoints will be needed, unless a heart curve is drawn.
Or, A basic heart curve could be scaled??? for an input.
The various curves and surfaces, etc., will need to be identified by e.g. Name or Color, in order to be selected for the various steps.
10889.16
I really appreciate the materials that you've post. I'm sure will have to know it very soon. The thing is, they seems to be a little bit too advanced for me (having the UI ready, etc).
I just found a discussion here regards scripts:
http://moi3d.com/forum/index.php?webtag=MOI&msg=7238.1
.. and the discussion there could be a good start for me: to draw objects using script like the following example from Martin.
script:
var factory = moi.command.createFactory( 'box' );
factory.setInput( 0, moi.vectorMath.createFrame() );
factory.setInput( 2, 20 );
factory.setInput( 3, 20 );
factory.setInput( 4, 20 );
factory.commit();
I think I could start learning from this humble beginning.
However, I can't find the right place to have the reference for each objects, i.e.: how to use moi.command.createFactory, what parameters needed, etc.
So, could you please point me the right direction?
10889.17 In reply to 10889.16
Hi Elang,
For using moi.command.createFactory(), the example you posted shows it, you pass it the string name of a factory, in what you posted that's 'box'.
In the regular box command the inputs to the box factory are filled in by picking a point to place the corner point and coordinate frame, and then the width, height, and extrusion values are filled in by either another point pick or by values that are typed in to edit fields.
In your example code it's setting values of 20 each for width, height, and extrusion.
If you instead had:
factory.setInput( 2, 30 ); // Input index 2 is width
factory.setInput( 3, 40 ); // input index 3 is height
factory.setInput( 4, 50 ); // input index 4 is extrusion
that would make a width of 30, a height of 40, and an extrusion of 50 units.
10889.18 In reply to 10889.17
So in general the setInput indexes is something that mimics the way we input them in Moi?
Still are there any reference list for each of the command? I'm hoping something like here:
https://learn.microsoft.com/en-us/dotnet/visual-basic/language-reference/functions/string-functions
... though a much simpler way is ok.
10889.19
Found something very interesting here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=10720.5
Is this contains all object in Moi?
10889.20 In reply to 10889.19
Hi Elang, I think there's a more up to date one here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=10857.36
I think it has all of them at that point in time that it was made but it's from quite a while ago.
Yes the regular commands fill in these same factory inputs, often times by connecting them to edit fields in the UI and also some inputs take x,y,z point values that are filled in by a pointpicker.
A script can just directly fill in the factory inputs instead which is what your example code there was doing.
Well, I cannot believe this.
I was working on a super simple BoxBasic script, and either Windows 11, or a recent version of Notepad++ renamed TWO entirely different .htm files to .html.
So nothing was working.
Also, my Windows 10 file manager shows both .html and .htm files as HTML Document.
Notepad++ does show the correct extension of an .htm file, or an .html file.
For MoI scriptwriters dealing with .htm files, is may be a good idea, in Windows 10 file manager,
to select view, and check the box "File name extensions", which will display the corresponding
.htm or .html extensions attached to the file name.
EDITED: 11 Nov 2022 by BEMFARMER
Here is a very simple script to create a box, using just the MoI Box factory.
The Box seems to be sitting on the x,z plane, so I may switch to the x,y plane, the original intention, with Height in the z direction.
This can be done by just re-ordering the order of the box factory inputs.
Note that there are more than one way to make this box. There is .update and .commit.
There is .calculate, and moi.geometryDatabase.addObject( box ), with objectlists.
This box is a solid, with 6 faces. If one face is deleted, the box is a joined surface, with walls and bottom of zero thickness.
The desired box has not been specified.
My concept of what the desired box could be, is that of a candy box, with open top, and 4 sides (walls), and a bottom, all of which have non-zero width.
One way to do this, as for the previous manual method several posts ago, would utilized a half dozen or so factories, in one script...
Here is Alpha4 version, with Height in z direction.
Just swapped box factory inputs 3 and 4.
ps Change a slider, then click on input label, to restore default dimension value.
10889.24
Wonderful! Thank you very much, Brian.
I'm sure I will learn a lot from your script.
- Elang
10889.25 In reply to 10889.24
In the past, when I just cannot get a script to work, by making a question, or request, Michael has provided a lot of tremendous help!
10889.26
attached a nod file created in nodeditor that makes boxes from any closed curve profile that can be scaled.
Not sure if this is the kind of thing you are after.
Barry
10889.27 In reply to 10889.26
Hi Barry,
You have made a very nice node!
Select a closed profile, e.g. Rectangle, Star, Circle, etc.
Run Box2.nod in nodeeditor.
10889.28 In reply to 10889.27
Thanks Brian,
the nodeditor as it’s uses for us non programmers.
Barry
10889.29
NE-Box
image host image host image host image host
EDITED: 12 Nov 2022 by WN
10889.30 In reply to 10889.29
Joinery!!! Nice WN.
Also Barry. Always great contributor! :)
Cool nodes process!
10889.32
Hi everyone, Thank you very much for such nice and helpful respond.
I'll learn a lot from all of you.
Please keep them coming.
Thank you and have a nice day!
Show messages:  1-12  13-32
