Point display in PDF Export
All  1  2-6
10887.2 In reply to 10887.1
Hi Grendel, sorry no there isn't currently any export of point objects in MoI out to PDF format.
You could try drawing in a Leader annotation object off of it and set it to have a dot arrowhead style although that will make a solid filled circle without an outline.
10887.3
Michael, I understand. Would it be possible to "trick" it by substituting a proxy circle line? If there was a script to "replace points with X object" or "replicate/place object on points" as an array function then I could simply make a small circle and place them on all selected points to get a point output. Is something like that available?
10887.4 In reply to 10887.3
Hi Grendel, I think one of Max's scripts does a copy to point objects:
http://moi3d.com/wiki/MaxScriptArchive
I think it's maybe the vclone one.
Or also this one:
http://kyticka.webzdarma.cz/3d/moi/#CopyToPoints
Maybe this can make something...
BoundingBoxCenterMultiple, CopyToPoints, VClone.
Damned Michael was more speedy! :)
10887.6
Michael, the copytopoints worked perfectly. Thank you for the direction and help.
Show messages: All  1  2-6
