Blend possible here?
 1-17  18-30
10883.18
Where is the mistake?
10883.19 In reply to 10883.18
I think the mistake is an internal face.
Much easy to help you if you post the model with the mistake to find it.
If it could help you I made in Moi a Subd with your first hand.
Moi is not the easiest tool for subd, but it's the only one I use now.
I takes much time but patience gives pretty good model.
As last one, you could improve it, because I'm not a specialist in subd.
Have fun...
EDITED: 19 May by PHIRO
10883.20 In reply to 10883.13
Hi Mala,
> Hmmm´...I just thought about SubD-Model the hand in c4d. But I fear I cannot combine and
> reimport the c4d polygonmodel to attach it onto the ring in MoI...
Starting with moi version 4 there is a sub-d converter that will allow you to bring a sub-d model created in a poly modeler into MoI as a CAD surface that can be booleaned and trimmed in Moi same as other surfaces.
That's available in the SubD palette on the side Pane.
Export out the SubD control cage from Cinema4D to an .obj file, then in MoI use SubD > Create > From file:
10883.21 In reply to 10883.18
Hi Mala,
Hard to tell without being able to examine the model.
But probably an n-gon face somewhere instead of all quads.
I'd recommend to do the sub-d modeling in Cinema4D instead, where you can find documentation and tutorials to help you. Then if you need to do some work combining it with other elements inside MoI use SubD > Create > From file in Moi to bring the subd surface into MoI.
My little advice for SubD sculpt modeling in Moi :)
Rustic but like this you will not have problem and possibilities to sculpt many things inside MOi Itself!
When a face don't want SUbDivided; the face(s) is enlighted so SsPlit them (P = SsPlit )
Just copy Move a face (Select "Only one" face + Ctrl + Move) then Bridge it ( B = SsBridge)
(you can select many faces and Copy Move them but after you are obliged to Select only 2 faces for Bridge them!!!
Verify if solid object is subdivisible with K (K = _Subdiv_beta9 ) then Undo and continue to Modelize!
here the polygon has 7 edges! (that works ! :) (Don't forget the bottom face! )
Last function is SsScale for Move Size Rotate selected Points' Face(s)
(not Shown above )
EDITED: 25 Oct 2022 by PILOU
And if you want a free Polygon modeler entierely interfaced with Moi and same Style Interface!
you have the true free gem : Rocket3F !
Moi3D <--> Rocket 3F
https://rocket3f.com
The only 3 limitations are
* Windows System
* 10 seconds waiting at the launch
* renew register each month (takes 5 seconds)
EDITED: 26 Oct 2022 by PILOU
10883.24
Hello Michael and Pilou,
thank you both for your comments and advices!
I have to make headpingpong first how to progress...
Warmest regards, Mala
10883.25 In reply to 10883.9
Fantastic.
10883.26 In reply to 10883.25
10883.27 In reply to 10883.17
<<Only using the command tabs seems to me a little bit strange
Why ? : it's the more speedy! 10 times more speed than go to click an icon! ;)
10883.28 In reply to 10883.12
What CNC Program do you have? Usually your CAM Program has the options for "Embossing" stuff on rings... From just your 2d geometry....
10883.29 In reply to 10883.27
command tabs vs. buttons - propably a question of mindset and excercise
10883.30 In reply to 10883.28
got no experiences with embossing in CAM. I´ll talk with them about. The company is in Italy. I think the shape is not under my control. Think´ about it and communicate with them...Thank you!
Show messages:  1-17  18-30
