How to shrink or resize multiple lines
All  1-5  6-13
10882.6 In reply to 10882.5
Thx for the infos!
Seems if the lines are 5 unities or less nothing is done for these lines!
Does this normal ?
10882.8 In reply to 10882.7
> Does this normal ?
Well the request was to chop off 5 units off the ends of each line.
If you do that to a line that is 10 units or shorter in size then there would be nothing left.
So yes that's normal for this particular use case for those lines to not be processed.
10882.9 In reply to 10882.8
OK all is clear now! :)
10882.10
Great!
Thank you!
10882.11
How about creating circles with 5 mm radius to the endpoints of each line, then use these circles to cut the lines? This should too works for arcs, no?
10882.12 In reply to 10882.11
<< 5 mm radius to the endpoints of each line, then use these circles to cut the lines? This should too works for arcs
Vclone by Max can help you for this!
Work for only one extremity of something selected: Lines , arcs; curves etc...
So apply one time then select all lines Press Tab and write Flip
re-apply Vclone so all extremities will have their "circles" ;) (not shown here)
EDITED: 4 Nov 2022 by PILOU
10882.13 In reply to 10882.11
Hi Elang,
Well whether it works for arcs or not depends on what result you need.
If you need to cut 5mm of "arc length" (distance as traveled like an ant walking along the curved arc), then no that wouldn't work.
If you wanted a result that placed the new arc's endpoint at 5mm "point to point" distance instead of arc length distance then yes that would work.
Show messages: All  1-5  6-13
