Flattening 3d to 2d
All  1-3  4-7
1087.4
Some other stuff while I'm at it....
The contoured object and planar elements are hidden in the 3dm file if you need them.
Michael T.
Michael Tuttle a.k.a. mictu http://www.coroflot.com/fish317537
EDITED: 4 Nov 2010 by MICTU_UTCIM
1087.5 In reply to 1087.2
Hello Michael
Thanks for the prompt reply, hopefully someone makes the plug in when the feature becomes available. Prefer not to go with Rhino as it is more than I need at this point.
In the mean time I did a bit more digging and found LaminaDesign for unfolding. It looks as new as MOI , hopefully just as good.
D
1087.6 In reply to 1087.4
Hi Mictu
Thanks for the suggestions, I was more after bending or networking a skin over a frame and then flattening it to precut the panels on a CNC machine . In particular the stitch and glue method of boat building.
Your method would be a good one if I was to build a form to make a fiberglass hull. ( but in reverse, like a bathtub)
Thanks for the ideas.
D
1087.7 In reply to 1087.5
Hi D - LaminaDesign does look very interesting. If you end up doing a project with MoI and LaminaDesign, it would be really cool to see the results! It looks like there is a demo version of LaminaDesign available, so hopefully you can use that to see if it will work for what you need to do.
Show messages: All  1-3  4-7
