Continuous surface with sharp edge in MoI only - Possible?
All  1-5  6-11
10865.6 In reply to 10865.5
Hi tuananhnp, here's the best that I've been able to come up with while keeping all the outer boundaries constrained.
This one is doing the regular Network over the whole thing initially, then trimming out a "dart" type hole and putting in a blend to fill it.
10865.7 In reply to 10865.6
That's a pretty good solution!
Although it still shows discontinuity at the top & bottom part of the "dart":
Thank you, Michael.
10865.8 In reply to 10865.7
If you can tolerate the bottom deviating from the original curve by some small amount (like 0.02 units) then you could do the cut like this instead and the bottom part should be smoother.
Getting the top to be smoother is probably going to be harder, the base surfaces have different surface normals at the point that they touch.
Do you know a free Zebra Analysing Surface online ?
A trick that can be made! ;)
10865.10 In reply to 10865.9
blender as 2 zebra shading options in Matcap.
Here's an example.
Barry
10865.11 In reply to 10865.10
Thx but it's not on line! ;)
There is another one inside Free DesignSpark Mechanical! ;) (A SpaceClaim light)
but it's some tricky! ;) and also not online! :( https://www.rs-online.com/designspark/mechanical-download-and-installation
Import your Step Moi File - draw anything a sphere for example
Call the Arborescence - Lock the Sphere - You can manipulate and edit your moi File! ;)
Here i keep the sphere but can erase it and change the color of the cube! ;)
It's also here a PDF3D exported and created inside Design Spark Mechanical! ;)
EDITED: 1 Oct 2022 by PILOU
Show messages: All  1-5  6-11
