Continuous surface with sharp edge in MoI only - Possible?
All  1  2-11
10865.2
Sorry guys I forgot to attach the 3dm file.
10865.3 In reply to 10865.1
Hi
> Network and Sweep produces 2 different results. Both are not continuous, I guess due to the sharp curve on top:
Right, yes that's to be expected - if you use a surface construction method and give it a curve with a sharp corner in it, that sharp corner is going to be inherited into the constructed surfaces.
The main way to avoid that is to do what you show and have a larger smooth surface with the sharp corner borders coming from a trimming boundary instead of being a direct part of the underlying surface.
> And it's a trimmed surface, so isocurves are not natural:
Ok, but why is that a problem? It's normal for many areas of a model to be made of trimmed surfaces.
In something like this where you want a smooth surface with an irregular boundary a trimmed surface is what you want.
Also It can tend to be helpful to work with the neighboring surfaces at the same time, instead of just one surface in isolation like you've been doing here.
Then you can make trims from things like 2 extended surfaces intersecting against each other.
10865.4 In reply to 10865.2
Hi tuananhnp, I've been trying a couple of different ideas but it's pretty difficult in general to combine sharp, smooth, flat, and curved all in different regions of the same patch.
The XNurbs plug-in for Rhino might be a good match for this.
10865.5 In reply to 10865.4
The robust & intuitive nature of MoI always yields some urge and curiosity in me to explore workarounds for problems like this. I often think: "What if I can do them all in MoI, even if it's time-consuming?". But I guess I was trying to do the impossible here. Just want to let you know how much I love MoI.
Maybe for now I should avoid constructing these kinds of curve combination from the first place, if I'm determined to use MoI exclusively.
XNURBS looks very promising, but it's quite expensive.
Thank you very much!
I really appreciate your help and suggestions.
10865.6 In reply to 10865.5
Hi tuananhnp, here's the best that I've been able to come up with while keeping all the outer boundaries constrained.
This one is doing the regular Network over the whole thing initially, then trimming out a "dart" type hole and putting in a blend to fill it.
10865.7 In reply to 10865.6
That's a pretty good solution!
Although it still shows discontinuity at the top & bottom part of the "dart":
Thank you, Michael.
10865.8 In reply to 10865.7
If you can tolerate the bottom deviating from the original curve by some small amount (like 0.02 units) then you could do the cut like this instead and the bottom part should be smoother.
Getting the top to be smoother is probably going to be harder, the base surfaces have different surface normals at the point that they touch.
Do you know a free Zebra Analysing Surface online ?
A trick that can be made! ;)
10865.10 In reply to 10865.9
blender as 2 zebra shading options in Matcap.
Here's an example.
Barry
10865.11 In reply to 10865.10
Thx but it's not on line! ;)
There is another one inside Free DesignSpark Mechanical! ;) (A SpaceClaim light)
but it's some tricky! ;) and also not online! :( https://www.rs-online.com/designspark/mechanical-download-and-installation
Import your Step Moi File - draw anything a sphere for example
Call the Arborescence - Lock the Sphere - You can manipulate and edit your moi File! ;)
Here i keep the sphere but can erase it and change the color of the cube! ;)
It's also here a PDF3D exported and created inside Design Spark Mechanical! ;)
EDITED: 1 Oct 2022 by PILOU
Show messages: All  1  2-11
