Script to select all edges and merge
All  1-3  4-6
10861.4 In reply to 10861.3
Careful Merge is also a Boolean trimming function! ;)
EDITED: 26 Sep 2022 by PILOU
10861.5 In reply to 10861.3
Hi Peticel, the problem is that the contents for a shortcut key can either be a command name or it can be script code to run.
But in your case there you've got both of those together.
You'll need to put in this instead:
script:moi.geometryDatabase.selectAll(); moi.command.execCommand( 'Merge' );
10861.6 In reply to 10861.5
Thank you, Michael. Works perfectly!
Kind regards,
Peticel
Show messages: All  1-3  4-6
