Linear scaling along curve
All  1-5  6-7
When you have your segments
Use the Flow function ! ;) (i was not enough speedy ! :)
Then use the VClone Above
Like this you have exactly that you want! But not just linear any thing! :)
Any object along a curve with scale changing! ;)
Max Smirnov archive : https://moi3d.com/wiki/MaxScriptArchive
EDITED: 20 Sep 2022 by PILOU
10858.7 In reply to 10858.5
I think the constant distance is exactly what I wanted. I will try it out! Trying to make a segmented curvy tentacle shape that tapers off towards the end, and I think this plug-in will do nicely. I'll check the ScriptArray plugin if need be. Thanks for the very fast support - as usual!
/Magnus
Show messages: All  1-5  6-7
