Thank you Michael.
Most of the code block is correct, but the two "table" code lines need to be removed.
(The lower "table" line is in the correct position, but the upper "table" line is many lines further up in the SidePane.htm code.)
I think that my mistake was failure to use the correct code block symbols initially, posting, and then trying to edit in the corrections. (?)
