Boolean issue
All  1  2-5
10852.2 In reply to 10852.1
Just ideas because that works not...too... :(
Increase the Scale *1000
Rotate the nut for dis-allign the Curves Generator
No Unit System
10852.3
hi
i have made a new bolean test with _NutsAndBolts script.
it works !
perhaps yous should try to make a new bolt ?
chri
Size: 115.6 KB, Downloaded: 38 times, Dimensions: 917x736px
10852.4 In reply to 10852.1
Hi Mik, the main problem is the offset - MoI's solid offset tool does not work well in cases where pieces need to be extended and intersected with each other.
The geometry that the offset produced has some bad corners in it now where edges are quite a ways off from each other instead of meeting up with a good tolererance:
So I'd recommend not to do the offset on the threads object.
10852.5 In reply to 10852.4
I understand.
Thank you, Michael.
Mik
Show messages: All  1  2-5
