Generate a sequence by loop nodes
All  1-4  5-10
10850.5 In reply to 10850.3
Thank you for your detailed reply.
I think I gave a too regular examples. If the sequence is {1,8,20,b,c,... }, becomes {1,9,29,29+b,29+b+c,... }.
The point of the question is, I didn't use the loop node correctly or the loop node has bug.
10850.6 In reply to 10850.4
But the sequence I want to generate is not limited to 5 or 8 numbers, and I hope to calculate more numbers.
I think maybe I didn't use the loop node correctly, or the loop node has bug.
When I'm dealing with objects or vectors, the loop node works correctly.
10850.7
Hi all.
Try this.
https://disk.yandex.ru/d/TxQgdTTMVRMs2g
image host
C:\Users\User\AppData\Roaming\Moi\nodeeditor\nodes\extensions
Copy the file to this location using the link. This is for Windows.
image host
EDITED: 16 Sep 2022 by WN
Message 10850.8 deleted 16 Sep 2022 by 1MI8
10850.9 In reply to 10850.7
That's great. Thanks for sharing.
This is the node I really want.
Very compact! Excellent!
Show messages: All  1-4  5-10
