Generate a sequence by loop nodes
All
1-3
4-10
Frenchy Pilou (PILOU)
16 Sep 2022 (4 of 10)
10850.4
Maybe this can help
Left Click on the Title of the Math node for obtain Edit Properties!
EDITED: 16 Sep 2022 by PILOU
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
1mi8
16 Sep 2022 (5 of 10)
10850.5
In reply to
10850.3
Thank you for your detailed reply.
I think I gave a too regular examples. If the sequence is {1,8,20,b,c,... }, becomes {1,9,29,29+b,29+b+c,... }.
The point of the question is, I didn't use the loop node correctly or the loop node has bug.
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
1mi8
16 Sep 2022 (6 of 10)
10850.6
In reply to
10850.4
But the sequence I want to generate is not limited to 5 or 8 numbers, and I hope to calculate more numbers.
I think maybe I didn't use the loop node correctly, or the loop node has bug.
When I'm dealing with objects or vectors, the loop node works correctly.
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
WN
16 Sep 2022 (7 of 10)
10850.7
Hi all.
Try this.
https://disk.yandex.ru/d/TxQgdTTMVRMs2g
C:\Users\User\AppData\Roaming\Moi\nodeeditor\nodes\extensions
Copy the file to this location using the link. This is for Windows.
EDITED: 16 Sep 2022 by WN
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
Message 10850.8 deleted 16 Sep 2022 by 1MI8
1mi8
16 Sep 2022 (9 of 10)
10850.9
In reply to
10850.7
That's great. Thanks for sharing.
This is the node I really want.
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
16 Sep 2022 (10 of 10)
10850.10
Very compact! Excellent!
My Moi French Site
My MagicaVoxel Gallery
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
Reply to All
All
1-3
4-10
