Another Fillet question / problem
All  1  2-3
10846.2 In reply to 10846.1
Hi scott, 2 adjacent faces that are coplanar fragments of the same larger plane can be merged using boolean union but there isn't currently an automatic way to merge together 2 extrusions.
So for the time being to merge them you would need to delete the current fragments and then make a larger extrusion going over the full extent and then join that in.
I've attached a version where I've done that, it should be easier to fillet this one.
10846.3 In reply to 10846.2
Thank you for the 'instantaneous' reply.
After perusing the forum messages, I wanted to ensure I didn't overlook some of your magic. For now I'll focus on streamlining my workflow as the best solution.
Thanks again.
Scott
Show messages: All  1  2-3
