Move from
 1-16  17-24
10845.17 In reply to 10845.16
Great. Thanks for making the video!
The second way was what i was thinking. Thanks for confirming it did what i thought. Have been away from my computer alot lately.
10845.18 In reply to 10845.16
When I try to execute this procedure I get an error as attached:
Size: 23.1 KB, Downloaded: 65 times, Dimensions: 1368x1045px
10845.19 In reply to 10845.18
Hi Marek,
The relative point input needs a point coordinate, either an x,y value (which will use z=0) or an x,y,z value.
Also if your locale's number system uses the comma as the decimal separator then put it in as a space between the x and y coordinates instead of a comma between them.
So either r-5,0 or r-5 0 if you use commas as decimal separators.
10845.20 In reply to 10845.19
Got it, finally!
The only way is to type in:
r-5 0
As both r-5 and r-5,0 return error.
This adds another functionality of sophisticated apps which cost at least 10 times more than MoI.
Thank you,
Marek
EDITED: 9 Sep 2022 by MARKY
Finally found a recorder compatible with the "Trapezoïd" of the Helper Line ! :)
Click Move the Cline without release on the black rectangle edge
I take & write here 7 Enter ... after the calling Trapezoïd then move the Clines
(you can also move them only by eyes on the complete values)
EDITED: 9 Sep 2022 by PILOU
10845.22 In reply to 10845.21
Got you.
Small problem, you need 4 or 5 mouse clicks.
Gets bigger if you have more objects to relocate.
10845.23 In reply to 10845.22
Yes but when you want a very precise distance...
10845.24 In reply to 10845.23
2 Moves or r-x 0 which is the little gem is the answer.
Show messages:  1-16  17-24
