Network and Sweep don't work
All  1-3  4-8
10837.4 In reply to 10837.1
Hi tuananhnp, for Network to work it needs to be able to unwrap the curves into a regular grid similar to latitude and longitude lines on a sphere going to a flat world map.
The part that doesn't work in your current setup is you're missing the "poles" where longitude lines should end at a common point.
In the attached version I have split up 2 of your closed curves so that there are poles and so they can make a 2D grid and now Network should work.
You may get a better result though using an actual SubD box and using the SubD converter under SubD > Create > "From file".
Some funny results with the same curves and the Boolean Intersection in some steps! ;)
Results are depending of the order of them!
10837.6
Thank you guys for those solutions!
10837.7 In reply to 10837.6
10837.8
Network to work it needs to be able to unwrap the curves into a regular grid similar to latitude and longitude lines on a sphere going to a flat world map. https://get-vidmate.com/index/ https://instasave.onl/saveinsta/
EDITED: 21 Sep 2022 by MANDELVID
Show messages: All  1-3  4-8
