Network and Sweep don't work
10837.1
Hi, I'm trying to construct a solid similar to the SubD box (left in 1st image) from several closed curves (right in 1st image).
I've tried Network and Sweep, but they gave weird results (2nd & 3rd images). Am I doing anything wrong here?
I have attached the 3dm file below in case someone wants to try.
Size: 462.2 KB, Downloaded: 44 times, Dimensions: 1165x676px
Size: 520.7 KB, Downloaded: 38 times, Dimensions: 1366x686px
Size: 539 KB, Downloaded: 37 times, Dimensions: 1366x685px
A possible way is Rail revolve.
If you prefer Networking, you have to separate curves, it seems.
You do it with 2 networks
Like this :
10837.4 In reply to 10837.1
Hi tuananhnp, for Network to work it needs to be able to unwrap the curves into a regular grid similar to latitude and longitude lines on a sphere going to a flat world map.
The part that doesn't work in your current setup is you're missing the "poles" where longitude lines should end at a common point.
In the attached version I have split up 2 of your closed curves so that there are poles and so they can make a 2D grid and now Network should work.
You may get a better result though using an actual SubD box and using the SubD converter under SubD > Create > "From file".
Some funny results with the same curves and the Boolean Intersection in some steps! ;)
Results are depending of the order of them!
10837.6
Thank you guys for those solutions!
10837.7 In reply to 10837.6
10837.8
Network to work it needs to be able to unwrap the curves into a regular grid similar to latitude and longitude lines on a sphere going to a flat world map. https://get-vidmate.com/index/ https://instasave.onl/saveinsta/
EDITED: 21 Sep 2022 by MANDELVID
