Fast fillet removal
 1-12  13-23
10834.13 In reply to 10834.12
No that was that you can do ideally inside Fusion...not yet and probably never in Moi ;)
In Moi Play with 2 sessions (or more) in the same time!
Copy Past your object before the fillet!
Ctrl +C, Ctrl +V of something selected is permit between any sessions open of Moi in the same time!
(depending of your hard memory available)
More easy than Save reload...
EDITED: 30 Aug 2022 by PILOU
10834.14 In reply to 10834.13
I'm really, really sorry, but I still couldn't get the gist of what you want to tell me.. (( Sorry.
10834.15 In reply to 10834.14
Nothing more simple :)
a Copy = Ctrl + C / Crtl + V
You work principally in Session A, Session B is your save "SpaceSphip" not filleted! :)
you can have any number of sessions in the same time
Minute 1
Session A : Object O very complex
Session B : Object O copied (from Session A) without Fillet
Minute 2
Session A : Object O Filleted
Session B : Object O - nothing to do
Minute 10 You don't want the Object O with Fillets for any reason so...
Session A : kill the Object O
Session B : Copy Object O (original) for the Session A
Minute 11
Session A : Object O not Filleted (because copied from session B )
Session B : Object O copied without Fillet - nothing to do - or can be receive a new object O modified without fillet you are not oblige to kill the first one...that becomes your data base of unfilleted objects!
etc...
All that avoid to calculate the unfillet (in general impossible in few time) an object at any time of it's conception!
It's very rustic but very efficient!
10834.16 In reply to 10834.15
Hmmm .. With difficulty, but - it seems - I understood.
We call such a pipeline "dancing with a tambourine".
All this is very nice, but I can't understand why, why should I do a lot of these useless actions (and still keep all this in my head), if I can - stupidly - open an object in spaceclay, delete a fillet (if it was created by mistake) - and continue to work calmly without wasting time on all these body movements (which you so kindly and diligently described)
And I'm not talking about the pipeline, I'm asking about the meaning !!
In theory, I can climb to my apartment on the 5th floor using ropes and climbing pitons.
But I prefer the elevator!
10834.17 In reply to 10834.16
here i don't kill the fillet object by caution in case of ...as you can see it's some speedy! :)
Very more speedy than your Spaceclaim video! ,)
Seems you don't understand that a function of Unfillet a complex object is not yet easily existing..in Moi or inside some other progs! :)
So we can find some tricky replacements! ;)
10834.18 In reply to 10834.17
I understand it perfectly! That is why I provided a solution to this problem using a third-party program.
That's all.
10834.19 In reply to 10834.18
So you have now 2 solutions !
But SpaceClaim is not a low cost prog...
10834.20 In reply to 10834.19
Yes you are right.
But there is also Plasticity, it is completely free and can also remove fillets.
Not everything is not as cool as SC, but still, still ...
10834.21 In reply to 10834.20
Beta of Plasticity is free yes but final product will more than the 25$ announced because
Kernel Parasolid is used against Kernel C3D! So price will be more than very low cost! ;)
I doubt there will 2 versions Parasolid / C3D but who knows! :)
10834.22 In reply to 10834.21
Wait - and see!
10834.23 In reply to 10834.22
Post your example file. Your spaceclaim video at 1.21 created malformed geometry. Luckily they wanted the entire feature set removed or else, oops!
“Removing holes” is in regards to untrimming trimmed surfaces, which is what spaceclaim is doing there and why it was brought up when you asked about removing fillets. It is the same thing. Not “different”.
Show messages:  1-12  13-23
