Fillet & Loft
 1-7  8-27  28-30
Maybe like this ;)
Kill the 2 faces
Fillet lateral edges (5) if you want same general fillet take Max 3.5
- Kill Face - Redraw curve by extremities - middle arcs... so 5 points ...Make Plane
Same other side
Sweep the 2 edges by Bottom / Top
Union All
Fillets wanted here 1
Quasi Max Fillet 3.5
EDITED: 29 Aug 2022 by PILOU
10832.9 In reply to 10832.6
Thank you for your time and detailed explanation! I will keep in mind - for the future - that this is not a typical case for MOI and take this into account when designing.
I just looked at how this chituation is solved by means of Plasticity, I decided to repeat it in MY, thinking that everything is simple and ... oops ..
Thanks again !!
10832.10 In reply to 10832.7
By the way, in the process of experimenting with fillets, I noticed an interesting point.
The adjoining chamfer in MOI is also formed with a radius (in this case, the chamfer "splits")
In plasticity, on the contrary, an angle is formed at the junction.
Sometimes it's useful, sometimes it's not.
The question is - is it possible to form the same angle in MOI or is it not provided constructively?
10832.11 In reply to 10832.9
Hi krass,
Yes, that's interesting that it works in Plasticity. I tested it in Rhino and ViaCAD and it didn't work in either of those.
It's definitely not a simple case with it collapsing down to a single point in the middle of the fillet surface.
10832.12 In reply to 10832.10
Hi krass,
You can in some cases enable the "Straight corners" option to inhibit the creation of corner juncture patches but it's not very reliable.
But in cases where it works it goes like this:
Having corner junctures enabled usually helps make fillets work better in MoI so if you need that type of control very often you should probably plan on exporting to a different app and then filleting there and then bring it back into MoI.
10832.13
I recorded a short video of solving the problem and getting the desired result.
Maybe someone will be useful.
https://youtu.be/Rke7gavSw7o
10832.14 In reply to 10832.12
Yes, of course I know about the "Straight corners" function in the fillet, but this is in the case of the "outer fillet".
And here is just the case of the "inner" radius, that's why I asked.
EDITED: 29 Aug 2022 by KRASS
10832.15 In reply to 10832.8
Frenchy, thanks! Very interesting experiments!
10832.16
Michael, I don't know why, but I can't add images and files to the forum anymore.
When added, it writes "Out of space" ... Where can I fix it?
Sorry for being a little off topic.
10832.17 In reply to 10832.16
Hi krass,
We are all limited in the amount of memory we can upload attachments to.
So it is necessary to delete some prior posted attachments.
Pictures can be replaced by alternate storage sites, such as imgbox.com, which frees up some attachment memory.
(See Pilou posts, for example).
I've used imgbox in the last few months, as a substitute for posting picture attachments,
but have never mastered how to use it, or how it works.
It seems like a user of imgbox should keep a list of addresses, URL's, of pictures that the user has uploaded to the imgbox site?
As well as backup copies of images.
https://imgbox.com/help
https://techgyo.com/imgbox-free-image-hosting-service-with-versatile-features
EDITED: 1 Sep 2022 by BEMFARMER
10832.18 In reply to 10832.17
2 bemfarmer
Hello, thanks! I do it!
10832.19
Michael, another interesting fillet puzzle.
I will write here so as not to produce topics.
So solid on the right.
I add some fillets to it and get such a solid as on the left.
Next, on the solid on the right, I CAN continue doing fillets (red, top)
And on the solid on the left - I don’t know why - I can’t make a single fillet anymore (even on the upper edge, like on the right)
Question - what did I break?
10832.20 In reply to 10832.3
Yes, I admit for the finished version it is hard to have those fillets!
10832.21 In reply to 10832.20
2 Psygorn (DRILLBIT)
I completely agree with you - it is impossible to make a fillet.
I do not understand - why and what is the problem! )))
10832.22 In reply to 10832.21
Hi Krass.
I switched to other units of measurement and here is the result.
image host
https://disk.yandex.ru/d/7bF1-_mvakjnWA
EDITED: 1 Sep 2022 by WN
10832.23 In reply to 10832.22
Hmmm... Very, very interesting.
I'll try it now, thanks!
10832.24
I was mistaken, most likely it is a small scale, zooming in, for example, as here in the picture, allows you to make rounding.
image host
10832.25
In the original scale ...
imgbox
it turned out only such a maximum fillet ...
imgbox
10832.26
By the way, about fillets in problematic and difficult places - I tried to test different variations of creation.
Velcome: https://youtu.be/CztDikLAlb0
10832.27 In reply to 10832.17
@Beemfarmer
About the ImgBox
- Download your image (s)
- Choose the Gallery wanted
- Start Upload
so...
you have just to copy to the forum...not very automatic...but very efficient and free unlimited..
and cool Gallery system! I use only Full size...
EDITED: 1 Sep 2022 by PILOU
Show messages:  1-7  8-27  28-30
