Default Colours
All  1-3  4-6
10827.4 In reply to 10827.1
Hi Brendan, if you set up the style colors how you want in a .3dm file you can then make those be used as the default styles by specifying that file as the startup template under Options > General > "Template file".
The styles will then be loaded from that file when MoI starts up or when you do a File > New.
MoI .ini file, line 5, shows the path to the template file.
Mine is in AppData. (Window's 11)
10827.6
Much appreciated - thanks guys :)
Show messages: All  1-3  4-6
