Surface normals
All  1-2  3-7
10824.3 In reply to 10824.2
Thanks for replying that quick. Yes, shading artifacts is the consequence of removing the shading normals. My workaround is to inset a additional face.
It occurs with cubes. Even when a light hits the surface, it stays black, while the face in the shadow is brighter..
By the way, I don't transform any of those cube-like object.
But maybe it's a Modo issue, I don't know. So I'm gonna place this in the Modo forum too.
For your info, I'm doing a archviz which contains a lot of cubes-like objects, all modeled in Moi3D and render out in Modo.
- Reggy
10824.4 In reply to 10824.3
Hi Reggy, what do you have set in MoI under Options > Import/Export > LWO options > "Vertex normals style" ?
10824.5 In reply to 10824.4
It’s set to Modo 501. I should try Modo 601 / Lightwave v10 or Lightwave v9.6.
Didn’t know these preference. Thanks, I’m gonna give it a try and let you know the results.
10824.6 In reply to 10824.4
Wow, thanks a lot, Michael! I set it on Modo 601 / Lightwave 10, and it solved the problem.
This saves me a lot of work. Thanks again!
10824.7 In reply to 10824.6
That's great Reggy, I'm glad you're working ok now!
Show messages: All  1-2  3-7
