MoI5beta custom color change, Changes MoI4 colors.
All  1-3  4-10
10823.4 In reply to 10823.2
> Also, the MoI5beta background custom color rectangle is stuck on the blue-ish color, despite showing
> the theme #4D4D4D.
> (The custom color rectangle is not getting reset in MoI5beta)
> Unless #4D4D4D is manually reset. (Select color box must have color picked, or numbers entered.)
This one does look like a bug. It's only happening for the viewport color button, not grid ones is that correct?
10823.5 In reply to 10823.2
The View background by theme, pops-up a rectangle, with the theme color, #4D4D4D, showing in the rectangle to the right.
This is nice because it tell what the default hex code is. The custom color may or may not be the same, but the default hex code can
be re-entered in the Select color box, to restore Custom color to theme color.
The Gridline and Accented Gridline behave differently. They do not pop-up the default theme colors in the rectangles, unless each, or either, of the two default colors is the same as the theme color .
They pop-up the Custom color [GOOD]. The user would have to look up the theme color elsewhere.
EDITED: 21 Aug 2022 by BEMFARMER
10823.6 In reply to 10823.4
Yes, the Grid color rectangle, when it shows up, is the custom color. (Similarly for Accented Grid color rectangle.)
Maybe the Background rectangle color should mimic the Grid rectangle color behavior?
I just stumbled across the behavior while mimicking MoI5 dark theme with Dino's MoI.css for MoI4.
The dark MoI4 looks a lot like the MoI5 dark theme, with some "minor" differences.
The dark themes seem easier on the eyes, at times...
I have not been doing "custom colors", except as these tests, and can always look up the hex numbers in the Theme interface.
I thing/guess that the background rectangle color should match whatever the current custom number is...
10823.7 In reply to 10823.3
Thank you Michael, for explaining the "matching ini" convention, etc.
10823.8 In reply to 10823.6
re: Maybe the Background rectangle color should mimic the Grid rectangle color behavior?
Yes I think so, I think I've got that tuned up for the next beta now. Thanks for reporting it.
Sounds great Michael.
Took me two tries, but I was able to restore MoI4 dark background, grid and accented grid, by typing in their hex values.
MoI3 automatically came along, except I have not pasted any form of modified MoI.css in MoI3, which I rarely use anyway.
One more observation, of little concern.
In Windows 11, hovering over the maximize button permits the entire MoI window to be placed, say in the upper right quarter of the screen.
This causes all but one of the menu buttons to be minimized.
After restoring the MoI window to full height, the menu buttons remain minimized.
Not a big deal. Kind of wondered if the menu size auto adjust can or could or should open up the menu's from the top down?
10823.10 In reply to 10823.9
Hi Brian, currently the palettes in the side pane do not retain any memory of which ones were opened and which were closed when they collapse down due to the main window being resized to be shorter.
So it's not very easy at the moment for them to automatically be restored when the window is sized larger. Maybe I can add that someday but it will need some supporting pieces to be set up.
Show messages: All  1-3  4-10
