Mirror of Max's script files
All
1-4
5-9
Psygorn (DRILLBIT)
10 Dec 2022 (5 of 9)
10816.5
Hello all,
Where can I get "Zsurf4"?
It seems it is not included in Max's mirror.
Edit: is the "Heightmap.v.0.6.2015.08.20.zip " the other name for Zsurf4?
EDITED: 10 Dec 2022 by DRILLBIT
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
bemfarmer
10 Dec 2022 (6 of 9)
10816.6
In reply to
10816.5
Link:
https://www.cadstudio.cz/en/download.asp?file=ZSurf
From what little I have read, ZSurf4 is a windows program from circa 2003, well before Max's script. Do the two scripts yield similar results?
It is said: "ZSurf - converts bitmaps to 3D NURBS surfaces"(This may well be False?)
Another link:
https://www.reidb.net/USGS.html
says: "Zsurf4 can be used to convert grayscale height maps to IGES surfaces (.IGS),..."
https://soulysolar.mudventions.com/?p=478
"zSurf4 is a utility that allows you to import a bitmap and export a surface." (IGES)
There is a forum topic on Zsurf4, via a MoI search.
EDITED: 10 Dec 2022 by BEMFARMER
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
Psygorn (DRILLBIT)
10 Dec 2022 (7 of 9)
10816.7
In reply to
10816.6
Oh Sorry, I thought Zsurf4 is also written by Max!
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
Michael Gibson
10 Dec 2022 (8 of 9)
10816.8
In reply to
10816.7
Hi Psygorn, yes like Brian writes above ZSurf is its own separate stand alone program which can import a bitmap file and generate an .igs file with a surface in it that can be loaded into MoI.
Some links and previous discussion here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=2423.2
Max's heightfield script is similar.
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
Psygorn (DRILLBIT)
10 Dec 2022 (9 of 9)
10816.9
In reply to
10816.8
Tanx Michael :-)
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
Reply to All
All
1-4
5-9
