Mirror of Max's script files
All  1  2-9
10816.2 In reply to 10816.1
Excellent!
I will make a double security archive here! https://moiscript.weebly.com/archive-max-s.html
(even maybe i have some more of them there! ;)
https://moiscript.weebly.com/scripts-de-max-smirnov.html
Done! (In English :)
EDITED: 16 Aug 2022 by PILOU
10816.3 In reply to 10816.1
Thank you so much, Michael!
10816.4
This so funny. I had not seen this before I uploaded the zips I had to Github. Thank you.
-Royce
10816.5
Hello all,
Where can I get "Zsurf4"?
It seems it is not included in Max's mirror.
Edit: is the "Heightmap.v.0.6.2015.08.20.zip " the other name for Zsurf4?
EDITED: 10 Dec 2022 by DRILLBIT
10816.6 In reply to 10816.5
Link:
https://www.cadstudio.cz/en/download.asp?file=ZSurf
From what little I have read, ZSurf4 is a windows program from circa 2003, well before Max's script. Do the two scripts yield similar results?
It is said: "ZSurf - converts bitmaps to 3D NURBS surfaces"(This may well be False?)
Another link:
https://www.reidb.net/USGS.html
says: "Zsurf4 can be used to convert grayscale height maps to IGES surfaces (.IGS),..."
https://soulysolar.mudventions.com/?p=478
"zSurf4 is a utility that allows you to import a bitmap and export a surface." (IGES)
There is a forum topic on Zsurf4, via a MoI search.
EDITED: 10 Dec 2022 by BEMFARMER
10816.7 In reply to 10816.6
Oh Sorry, I thought Zsurf4 is also written by Max!
10816.8 In reply to 10816.7
Hi Psygorn, yes like Brian writes above ZSurf is its own separate stand alone program which can import a bitmap file and generate an .igs file with a surface in it that can be loaded into MoI.
Some links and previous discussion here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=2423.2
Max's heightfield script is similar.
10816.9 In reply to 10816.8
Tanx Michael :-)
Show messages: All  1  2-9
