stippled line variable point spacing from raster
 1-8  9-28  29-48  49-60
Draft:
Preliminary outline of script to order pre-existing points on a curve.
The result would be an array or objectlist of the points, in order
from the curve startPt to its endPt. (Flip option?)
Select the curve.
Clone the curve.
MoI5beta: Merge the cloneCurve, to get rid of any former segmentation.
(The cloneCurve probably cannot cross over itself?, or else do...?)
Select the points on the curve.
Remove duplicate points.
Select the desired start point of the cloneCurve.
Compare desiredStartPt with actual startPt of the cloneCurve and Flip cloneCurve if necessary.
Trim cloneCurve with the pre-existing points.
Get the segments, which will be in order from start to end of curve.
Place desiredStartPt in orderedPtList objectlist.
Get the endPt of all of the segments, one by one, and place them in orderedPtLIst.
Delete cloneCurve
Maybe there is a better way, or MoI already can order points on a curve?
10809.50 In reply to 10809.49
You can use the dropPoint( pt ) function on a curve or curvesegment. Given a 3D point it will return a number for the parameter value in the curve's domain. You could then sort by the parameter values in ascending order.
It may be problematic if you have a self intersection though and if you are trying to drop a point right at that self intersection.
10809.51 In reply to 10809.48
> I may be mistaken, but other than CustomUI, MoI does not have a way to see these "extra" commands, like Flip, Make2D, Merge, Rebuild, RemoveDuplicates, etc.
I'm somewhat of a minimalist when it comes to making changes to MoI's UI, so rather than using CustomUI, I borrowed Max's Scripts menu and made a stand-alone version called Extras: https://moi3d.com/forum/index.php?webtag=MOI&msg=10353.1 which then makes it easy to see the "extra" builtin commands as well as those that have been added.
--Larry
10809.52 In reply to 10809.51
Have you an image of the UI result ?
10809.53 In reply to 10809.48
Brian,
Thanks for pointing out SelectDuplicates.
- Peer
10809.54 In reply to 10809.50
Thank you very much Michael.
I recall dropPoint() from a while back.
Regarding curve self intersection, (crossover/ overlap), potential problems, options might include:
Ignore it and hope for the best?
Test for it and eliminate the point? Or eliminate the point?
Test for it and work around somehow?
Rely on user to select only "well behaved" curves?
During a google search of ordering points elsewhere on the internet, I remember reading something like:
"once you have the parameter "t"..."
but it was vague and a meaning did not register.
Name of script?
My current name favorite is stippleArray.
Previously the name was going to be luminArray or luminanceArray, or gradientArray, but
Lumin is the name of, or in the name of, several companies and products.
I guess Peer is doing stipple research or stipple addition?
10809.55 In reply to 10809.51
Thank you Larry for the link to your script.
I like your script.
It is alphabetical, ignoring the underline prefix.
It does duplicate listing of some scripts.
(I'm thinking the underline is obsolete?, Or does not add much to the display?)
I do still want a few of the other customUI features...
Maybe MoI6 could have an "detailed" user interface for these "extra" scripts?
Subcategories?, Descriptions? ...
I put "extras" in the MoI startup folder in AppData, (Windows 11)
EDITED: 18 Aug 2022 by BEMFARMER
10809.56 In reply to 10809.54
I don't know enough about what result you're trying to get from your script to advise on this.
But if the goal is to have it work as an adjustable function curve, then it would probably make sense to expect that the curve should not be self intersecting and should have just one y position for every x value.
With GIMP2.10.32, after an ordeal due to not knowing the user interface, I was able to make a gradient that looks much like PEERS.
GIMP2.99.10 is in test phase for eventual GIMP3, but still has tiny icons on 4k monitor. Maybe the icons can be enlarged, after another ordeal.
The user interface apparently has, or will have, differences from older versions.
The newer test version has sRGB.
Transparency setting gone???
Size: 325.5 KB, Downloaded: 35 times, Dimensions: 1000x500px
With Windows 11, the taskbar can be set to be a tiny sliver at the bottom of the screen.
Hover over it opens up the taskbar.
RightClick taskbar brings up Setting > Personalization, go to Taskber behavior > Checkbox: "Automatically hide the taskbar"
10809.59 In reply to 10809.55
Hmm, I've not noticed it duplicating scripts in my usage. I wonder though, do you happen to have something like two scripts named foo.js and _foo.js? That would produce an apparent duplication, but only because there were two scripts with related names. If you can provide any other clues as to what you're seeing of this duplication I'd appreciate them.
I believe the underscore prefix was an early means of keeping users' scripts separate from MoI's scripts & is now unnecessary with AppData/commands. However since the prefix is part of the name I wanted to display it, but alpha sorted as you note.
--Larry
This site explains RBG colors well, and the mouse can hover over a color to see the values.
https://www.rapidtables.com/web/color/RGB_Color.html
There are other tables as well.
Let a gradient be 256 pixels wide.
There are only 256 values for each R, G, or B number.
So a gradient made up of grey colors, from White to Black, could have RGB numbers such
that Rnum = Gnum = Bnum, in the integer range of 0...255.
The numbers for White are ( 255, 255, 255 )
The numbers for Black are ( 0, 0, 0 )
The average of the three numbers could be used.
To add up various sums of numbers, each should be subtracted from 255, to invert a White to Black gradient, to calculate when a sum exceeds a threshold number. (Assuming MoI points are more dense for darker regions.)
For 256 pixels the sum of the numbers could be an arithmetic series. As well as sums of sequential terms of subsets of the values.
The number of terms whose sum exceeds a threshold number can be calculated, with other than brute force:
https://math.stackexchange.com/questions/1624580/how-many-terms-in-arithmetic-series-where-sum-1000
Such a gradient image that is 512 pixels wide could have pairs with the same average value of the pixels.
EDITED: 19 Aug 2022 by BEMFARMER
Show messages:  1-8  9-28  29-48  49-60
