perspective projection 2D onto 3D
All  1-2  3-8
10807.3 In reply to 10807.2
Michael,
Wow! That is so cool that you wrote a script to do this, and in so few lines too!
I am very excited to use your new script and your old cplane to viewplane script tomorrow. I already tried both out and they look quite promising.
- Peer
10807.4 In reply to 10807.2
Hello,
The ray tracing script above didn't quite do what I want, so I spent the day trying to modify it. Now it does what I want about 2/3 of the time:
but sometimes it hangs (Calculating...) after doing a couple points.
If I terminate the script by hitting Save then I see that all rays were committed, but only the first 2 intersections were found:
I'm running this in v5beta on macOS. Please help me find my bug.
To test:
open attached 3dm file
run ViewManager script and select view1
select "test pts" from Objects
select top face of object
run script
//v2 August 9, 2022
//convert a vector into a unit vector (length = 1)
function LengthSq( v )
	return ( v.x * v.x ) + ( v.y * v.y ) + ( v.z * v.z );
function Normalize( v )
	var lensq = LengthSq( v );
	if ( lensq > 1.0e-12 )
		v.scale( 1.0 / Math.sqrt( lensq ) );
//appends elements of 2nd object list to first
function CombineLists( targetlist, fromlist )
for ( var i = 0; i < fromlist.length; ++i )
targetlist.addObject( fromlist.item(i) );
//draw rays from selected point(s), through camera point, and beyond
function DoViewRaysThroughPoints()
	var pts = moi.geometryDatabase.getSelectedObjects().getPoints();
	if ( pts.length == 0 )
		moi.ui.alert( 'error - no point objects selected' );
		return;
	var faces = moi.geometryDatabase.getSelectedObjects().getFaces(); //ObjectList
		if ( faces.length == 0 )
		moi.ui.alert( 'error - no face objects selected' );
		return;
	var camerapt = moi.ui.mainWindow.viewpanel.getViewport('3D').cameraPt;
	for ( var i = 0; i < pts.length; ++i )
		var ptobj = pts.item( i );
		var dir = moi.vectorMath.makeVector( camerapt, ptobj.pt );
		Normalize( dir );
		var line_length = 150.0;
		var startpt = ptobj.pt; //ray starts at selected point
		//ray goes through camera point and line_length beyond
		var endpt = moi.vectorMath.createPoint( camerapt.x - dir.x * line_length, camerapt.y - dir.y * line_length, camerapt.z - dir.z * line_length );
		var factory = moi.command.createFactory( 'line' ); //create ray
		factory.setInput( 0, startpt );
		factory.setInput( 1, endpt );
		var ray = factory.calculate();
		factory.commit(); //plot intersections only and not rays by commenting out this line
		CombineLists(ray,faces) //append face Objects to ray ObjectList so that ray can be intersected with faces
		var iFactory = moi.command.createFactory('intersect');
		iFactory.setInput(0, ray);
		iFactory.commit();
DoViewRaysThroughPoints();
EDITED: 3 Mar 2024 by PEER
10807.5 In reply to 10807.4
Hi Peer, I'm trying to go through your steps but after I load the .3dm file and restore the saved view, I get this result:
The problem here is that the points are not positioned to be visible inside the view, they seem to be located somewhere behind the 3D view's camera point.
10807.6 In reply to 10807.5
Michael,
The points should be located behind the camera point. They're on the "film plane" of the camera and will be projected out onto the 3D object. Like converting the camera into a slide projector. See screenshots above where rays all go through a point. That's the camera point.
- Peer
10807.7 In reply to 10807.6
Hi Peer, ok I see now - I had previously thought the rays would start at the camera point and go forward. You may need them to be a little longer if they're starting behind the camera point. Also the factory system may not be expecting to have a factory call both calculate() and also be used with update()/commit() as well with the same factory.
Does the attached version work any better for you?
10807.8 In reply to 10807.7
Michael,
Thanks for teaching me that calculate() and commit() shouldn't be used on the same factory and for showing how to add the factory output to the geometryDatabase in another way.
- Peer
Show messages: All  1-2  3-8
