converting parametric 2d curves and circles to polylines
All  1-6  7-16
10797.7 In reply to 10797.6
Hi Pior,
> Is there any way to have this is part of the export settings, so as to not have to
> tweak the ini each time ?
I'll see about adding it to the DXF export options dialog.
> Also, is there any way to perform this kind of conversion without having to even
> export/reimport at all (that is to say, getting to the result from within the work scene) ?
You could use the ReconstructCurve script that Brian wrote about above.
10797.8 In reply to 10797.6
Hi Pior,
I would say that Michael's answer is the best and quickest to export the desired type of objects.
But if you wanted to separate your curves, and run reconstruct only on say "arcs", and keep the line segments as lines:
As of MoI4, there is a curve property to see if the curve is a line:
crv.isLine - Property that returns true if the curve has the shape of a line.
https://moi3d.com/forum/index.php?webtag=MOI&msg=7777.1429
So if separate is done on the rounded rectangle, the curves that are lines can be separated out, and kept as lines.
The arc's can have reconstruct curve applied to them, to make them polylines.
Then rejoin the original straight lines, and the new polylines.
This is a very bare bones outline of a script.
The required polyline desire should be described in detail.
Which curves are to get turned into polylines.
Polyline length/numpoints.
etc...
So maybe a script could be written that would do this?
At this time, I do not have the time to attempt a script.
There are other curve properties listed in the link.
10797.9 In reply to 10797.8
Hi Brian, also you can select arc and circle curves in v5 using the Scene Browser:
10797.10 In reply to 10797.9
Great suggestion on the new curve types "menu"
So the reconstruct could be done manually, with help from MoI5. (?)
Something like:
Hide existing lines and polylines.
Apply reconstruct to arcs and ellipses and whatever other curve types.
Nothing gets missed...
10797.11 In reply to 10797.9
Just for general information, I'll have to learn how the curve types work, in the scene browser.
What gets hidden,
What gets unhidden
-Brian
10797.12
Between the UseSimpleEntities flag and the special ReconstructCurve script from https://moi3d.com/forum/index.php?webtag=MOI&msg=10719.1, I believe I have pretty much everything I need to address this scenario.
I am still a bit confused by the DXF export dialog though - shouldn't the DXF export be made of polylines if the user choses so in the export options, regardless of the state of UseSimpleEntities(y/n) in the .ini ?
So perhaps this panel needs some clarifications as to what the options do and do not do, and the relationship with the UseSimpleEntities flag ...
[Edit] : Oh OK I think I get it now. If a part has corners made out of circle sections (that is to say, perfectly round fillet corners), this part will indeed export out as polyline if the DXF exporter option is set to Polyline *and* if the whole thing is combined and connected before export. But if the part is made out of multiple detached bits before export, then the circle sections of the filleted corners will be recognized as such ... and therefore these circle segment curves will not be exported as polylines (except if the are forced to do so when UseSimpleEntities = n).
I understand that this "makes sense" once one knows about the concept of SimpleEntities, but I must say this is far from intuitive and would indeed benefit from some explanation text in the export dialog ...
EDITED: 7 Aug 2022 by PIOR_O
10797.13 In reply to 10797.12
Hi Pior, the way it works is if UseSimpleEntities=y (which is the default), then if a curve is a line, circle, arc, or polyline it will be written as a LINE, CIRCLE, ARC, or POLYLINE entity type in the generated DXF file.
If it does not get written as one of those specific entity types (either because UseSimpleEntities=n or if it is not a line, circle, arc, or polyline) then it will be processed as a general curve and will use the processing specified in the dialog for "Write curves as", either writing a SPLINE entity or converting it to lines and writing a POLYLINE entity.
No, because if it worked like that then UseSimpleEntities would not do anything and there wouldn't be any way to write LINE, CIRCLE, or ARC entities.
If you want everything to be written as polylines, then set UseSimpleEntities=n in moi.ini and you should not get any LINE, CIRCLE, or ARC entities being written anymore.
10797.14
Hello ! Indeed - I figured it out and appended my previous post ... probably just as you were typing your reply :D
All that said, since the behavior of selecting "polylines" in the export dialog is indeed dependent of the state of UseSimpleEntities, then I would say that this does require for the flag to be switchable in the export options indeed as briefly mentioned above - especially since one would assume intuitively that a "circle segment/arc" is a subset of the group "curve" ... even though in the DXF sense they are distinct separate entities.
10797.15 In reply to 10797.12
Hi Pior,
> perfectly round fillet corners), this part will indeed export out as polyline when the exporter
> option is set to that *if* the whole thing is combined and connected.
If you have a curve that started out as a rectangle and then had corners filleted, then that whole curve is not a line, circle, arc, or polyline and so will not be processed as one of those entities, it will go through general curve handling.
If you use Edit > Separate to break the joined curve into separate smaller curves then you will have 4 lines and 4 arcs and so in that case if UseSimpleEntities=y it will write those out as LINE and ARC entities.
10797.16 In reply to 10797.14
Hi Pior,
> since one would assume intuitively that a circle segment is a subset of the group "curve" (even though in the DXF sense they are different entities).
The term "Curve" in MoI terminology has a specific meaning, it's a wire object that has a child list of Curve Segments.
An arc that is contained inside a parent curve is not a "Curve" in MoI, it's a "Curve Segment".
Show messages: All  1-6  7-16
