Ver 5 Notes Feature - Possible to write a note within a script?
 1-17  18-22
10793.18
Hi Michael, I like the look of these "notes" feature in V5.
I might help me save some of the gems in this forum ;o)
Understand this is almost brand new, but do you think it
would it be soon be viable to be able to export (or import)
this note data into a .csv?
Can see some pretty good ways to use this for simple job
costing etc.
Kindest
Stefano
10793.19 In reply to 10793.18
Hi Stefano, for "Notes" you can get them in v5 under File > Notes.
That's just one piece of text, so I'm not sure how you would want that in .csv form?
Then there is also "Document user text" which scripts can use to store Key / Value pairs of text.
Is it the Document user text that you want to export to .csv ?
10793.20 In reply to 10793.19
Hi Michael, I was looking at the user values behind the
The object properties “details” initially thinking this could be useful.
Maybe this is only for storing scripts or could any values be assigned under key/value
Example
Key = object name
Value = object name
Key=cost/sqm
value =100
Key = object m2
Value = 1
Export this to csv - you’d have a list of 3 columns
and 3 values. 4th column could be a calculation in excel.
Idea to bring in object data into key values would make this very interesting. Maybe we could quote from a drawing.
10793.21 In reply to 10793.20
Hi stefano, so the user data is primarily intended to be a way for scripts to store data on either the document or on individual objects.
The script can use a unique name for the "key" part to avoid having some other script trying to store data in the same spot.
Scripts can access document user text by using these functions:
moi.geometryDatabase.setUserText( key, value );
var text = moi.geometryDatabase.getUserText( key ); // returns undefined if no user text is there.
var list = moi.geometryDatabase.getAllUserText();
moi.geometryDatabase.removeUserText( key );
moi.geometryDatabase.clearAllUserText();
Document user text is stored inside .3dm files.
The user can see and add or modify document user text values in the UI under File > Notes > “Document user text”.
User text can also be set on individual objects. The UI for setting these is under Details… > Object user text.
The object level user text has the same functions that are on the document:
obj.setUserText( key, value );
var text = obj.getUserText( key );
var list = obj.getAllUserText();
obj.removeUserText( key );
obj.clearAllUserText();
MoI itself does not currently make use of any user text value, it’s there for scripts to use if the script wants to store some data on particular objects or for the document.
> Example <...>
Sure, you can set these values on the user text. They will only be very useful though if you have set up a script that will access those values and do something with them.
Do you mean you want something like column A quantity, column B object name, column C cost/sqm ?
It is possible for a script to write to a text file. Some info here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=9665.2
10793.22 In reply to 10793.21
hi Michael - this MOI3D Notes V5 and the future looks very powerful!
Especially the object detail side of things...
I will work out a few more concise examples of how I might
use object data values - need some paint to dry 1st...
Stefano
Show messages:  1-17  18-22
