How to smooth curves or lines?
All  1-5  6-11
Here is the Savitzky–Golay filter method that might help. (?)
"The method has been extended for the treatment of 2- and 3-dimensional data."
https://en.wikipedia.org/wiki/Savitzky%E2%80%93Golay_filter
The math looks tough, but might be comprehensible with much study.
3rd and 4th derivatives?
Looks like javascript would not be adequate for 3D. (?)
There are two Convolution Coefficient Calculator software packages available for free download.
No Idea how NURBS formulas would apply.
Found all kinds of weird names and topics with a search of Smoothing Curves.
The other day, read article about why windshields have those dot/shading patterns, near edges.
EDITED: 28 Jul 2022 by BEMFARMER
10790.7
Dear all,
many thanks for your help!
First I will use curve corrected by Michael. Thanks for this!
Also very interesting is the method of Phiro, but how do I get these features out of hiding?
- Bodo-Lutz
10790.8
Hello,
Would it be possible to modify the "Rebuild" script so that the reconstructed curve automatically takes the default active color or another color than that of the original curve?
The "ReconstructCurve" script, on the other hand, sets the color of the original curve to locked color and sets the color of the reconstructed curve to the default color automatically!
I may not be very clear in my explanation!!!
- Zooen
10790.9 In reply to 10790.8
Hi Zooen,
Yes it's possible to modify the Rebuild script to do that.
You would need to edit the Rebuild.js script inside of MoI's commands folder.
Near the end of the script there is a call to factory.commit(); , you would need to add in this line right before the call to factory.commit() :
	factory.getCreatedObjects().setProperty( 'styleIndex', moi.geometryDatabase.activeStyle );
	factory.commit();
10790.10 In reply to 10790.8
A few years ago, with Michael's help, I did some different color curves in JacobianFunctionGraphMod script.
This might help with styleIndex script code.
And maybe color change in another script, cannot remember.
10790.11 In reply to 10790.9
Thanks Michael,
Excellent, This simplifies my work and makes it easier for me to compare the original curve and the reconstructed curve when I apply a tolerance of 0.001 for example or a high number of points (the two curves being very close).
- Zooen
Everything that is imagined and invented is true, you can be perfectly sure of it.
EDITED: 6 Aug 2022 by ZOOEN
Show messages: All  1-5  6-11
