Modeling rocks
All  1-3  4-14
Srictly in Moi3D you can use SubD functions by Max Smirnov for some blocky rounded rocks ;)
10786.5
Something like that will do...is there anyway to have a rougher surface?
Thank you!
10786.6 In reply to 10786.5
We have been using MOI3D to create primitives for an almost free ($6 donation) surface modeling program called MeshMolder. https://www.meshmolder.com/
In these images we see a Sphere deformed by pushing and pulling points in MOI3D then exported as .OBJ. It was then imported to Meshmolder for surfacing with a rough texture. The whole process took just a few minutes. The pushing and pulling can cause surface breaks which can be fixed in Meshmolder.
MOI3D and MeshMolder make for a very good combination of tools. Ultimately, the developer of Meshmolder hopes to have a similarly priced rendering engine.
Size: 164.4 KB, Downloaded: 113 times, Dimensions: 1193x812px
Size: 261.9 KB, Downloaded: 86 times, Dimensions: 1193x812px
In Moi you can make rocks in "hard surfaces"
like this https://www.freepik.com/premium-vector/big-stone-with-rough-surface-cartoon-rock-boulder-isolated-white-background_22143143.htm
But not this...too difficult to have this level of detail! ;)
10786.8
one way can be this:
Download 3D rocks models and convert these quad mesh topology objects with Blender (a free program) and then import them into Moi3D as subdivision surfaces.
tutorial triangulated mesh to quad
and with another free application
Be careful not to use a high resolution.
Here in this link you can download rocks suitable to be imported into Moi3D for free.
https://free3d.com/3d-model/rock-boulder-and-stone-collection-236212.html
Below those rocks imported as SubD without remeshing because they are ready with quad topology.
Greetings.
10786.9
Here's a great way to model flat edge rocks.
1.) Draw irregular polygon shapes on each of the 3 axes (I used three 5-sided shapes).
2.) Select all three closed shapes and run the boolean merge command.
3.) Delete all the extraneous parts and you're left with a rock shape.
It's hard to control with any artistic eye, but the results are very easy to produce.
I found that you can "find your groove" when doing this process and make oblong rocks or whatever.
I'd imagine you could make the rock more "shale-like" if you change the lines to slight concave curves.
A "tumbled rock" look could be achieved with convex curves.
Nothing beats the SubD process for boulders and round river rock though.
Note: I should mention that Pilou made me aware of this way of modelling. He's a genius!
-- Cody
EDITED: 16 Mar 2023 by ECHOLOCATING
10786.10 In reply to 10786.9
:) Cool...you must now make some landscapes render with them! ;)
Not made here but look this other trick ;) Input an image of your Moi's Objects (your rocks) inside Wombo with some % influence ...et voilĂ ! :)
https://www.wombo.art/
Or in direct you can also with The magic free Wombo ;)
tiny cubic geometrical rocks filling landscape
EDITED: 16 Mar 2023 by PILOU
Here with a poly modeler but that will be exactly the same in Moi3D! :)
Just use the ExplodeMove Function after any Trim (Press Tab write ExplodeMove) hidden function...
Other method
Boolean Merge + Fillets
With Voronoi! ;) The more easy of all technics! ;)
Select all
Boolean Merge + Explode Move! ;) Fillets on some pieces if wanted...
10786.14 In reply to 10786.13
You win, Pilou! ;-)
Show messages: All  1-3  4-14
