fillet error
All  1-5  6-9
10784.6 In reply to 10784.5
Yes, well, actually, I want to apply a fillet to all those lines that remain of the model, only in the screenshots, mark those because that is where the problem lies, and I know that the problem is there, so I don't know how to solve it :)
Size: 572.5 KB, Downloaded: 34 times, Dimensions: 1425x973px
10784.7 In reply to 10784.6
Hi Avila, I got rid of that edge by separating out the surfaces on either side of it and doing an "untrim" (that's where you select the trim boundary edges and use Delete) then built a new revolve that had a profile curve that was a single segment so it would make one single face when revolved.
Then revolved and trimmed and joined.
Without that edge there it should be easier to make a fillet go throught there:
10784.8 In reply to 10784.7
Hello, I am sorry for the ignorance, but I do not understand!
10784.9 In reply to 10784.8
Hi Avila, well it is a simpler process if you have a version saved off with your original generator curves. Much of the process I described above is about untrimming the model to recover the underlying base surfaces from which generator curves can be extracted. There is a tutorial on these techniques here:
Object repair tutorial
But the goal of all of that is to get these generator curves:
Currently with that curve in 3 separate pieces when you revolve it it will make 3 faces, one for each segment:
The change that is needed is to make that curve made up of only one single segment instead of 3 segments, so that it will make one single face when revolved:
The combining can be done using the Rebuild command in v4 or the Merge command in v5.
Show messages: All  1-5  6-9
